Question about Kenmore Elite 45986 Front Load Washer
Need to clean my filter on Kenmore Elite he3t--where is it?
I think there's something stuck in my filter, so I removed the kick plate, but don't know exactly what the filter looks like or how to check it.
  • 116 Answers
FIRST GET ALOT OF TOWELS MACHINE HOLD 3 GALLONS OF WATER STILL THERE IS A PLASTIC PUMP W/ ROUND HANDLE REMOVE HANDLE COUNTER CLOCKWISE AND REMOVE WHATEVER IS IN THERE
Posted on Nov 30, 2008
  • CycleChild Feb 25, 2011
    t would not complete a load and would stop and blink 0E code. This is great Now i dont need to call the repair man!
I have the Kenmore Elite HE3t and the control panel lets me change the settings but the door stays locked and the drain pump (off the filter) keeps going but there is no water to drain...cleaned drain out...
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Please check this video for cleaning:
Hope this helps... Please post back if you need more information.
Daniel
Mar 31, 2011 | Kenmore Elite 45986 Front Load Washer
I have the kennmore elite he3t. Error code f 02 and it will not drain Is there a solution to this problem you know of?
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Jan 03, 2011 | Kenmore Elite 45986 Front Load Washer
My Kenmore elite he3t is giving me a problem in the spin cycle. Even thought the spin setting is set on high or extra high, the drum turns very slowly and will eventually stop and the washer starts...
The machine will not advance to the high-speed spin cycle unless the water is drained first. The F02 error code manifests this condition as it means draining problem. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working. The display can be cleared by pressing the Pause/Cancel button twice.
Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Dec 20, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3t select wash mode press cycle start nothing happens on lights blinks
Disconnect the power cord, PLEASE. Remove the kick plate on the bottom front by removing the 3 screws below it. You will need a hex socket and extension or a torx screw driver. If there is water in the machine and it will not drain you will need a shop vac and some old towels to catch the water when you open the filter. Now, you will see the filter in front of you. Have the towels ready and vac turned on. Quickly unscrew the filter cap and stick the vac hose right in the filter to catch the water. Clean the filter cap. Did you find any socks, money or other debris? If yes that may have been your problem. Put the filter back on and HAND tighten well. Test the machine. From now on empty all pockets before you do the laundry
Dec 19, 2010 | Kenmore HE3T Washer
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
LOCATION OF LINT TRAP?
Remove 3 screws from the bottom front panel and drop it down. The pump will be in front of you on the bottom.
Mar 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front-load
you must remove bottom panel ,,in the center front you will find pump,,remove pump filter,,always unplug first..it has slugg,..than after you clean filter run your unit once a month with a pint of bleach and hot water only..also wipe your rubber gasket or bellows with a touch of bleach..
Dec 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3t washer
remove fill hoses at wall and washer ends look for a screen in hose at faucet end and 1 in washer fill valve pull and clean them be sure to reinstall screens before reconnecting..also fluch hoses out after reconnecting to faucet end and before reconnecting to washer to flush any trash/sand that be in them
Aug 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3t
F2 is a drain erro. Take the 3 screws off the botom panel in the middle, bottom you will see a large white plastic looking pump. this unscrews counter clock wise. have something ready to catch the rushing water. The trap is probably full of the rubber backing or strands of the rug. After you unscrew it, there is a trap there that can be cleaned. You may have to repeat this a couple of thimes to get all of it out.
Jun 13, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
1,488 people viewed this question
Sal De
fordexpert
Robert Rankin
