Question about E-Machines eMachines Desktop PC
I can't documunt on my hard drive
I have the e machine can't find documut on my hard drive
  • 837 Answers
Have you done a search for it and make sure that the advanced options are set to look in hidden folders
Posted on Nov 23, 2008
What type of hard drive does a Toshiba e-Studio 3511 copier take?
The hard drive is a regular SATA 3.5 hard drive, not 2.5 ( laptop size).
Also you need to make sure that no OS files were residing on the hard drive, the copier will not function without the missing files system.
Sep 26, 2014 | Toshiba E-Studio 3511 Color Copier
Hard drive not found hp pavilion ze5730us
If this machine is running XP, beware. It is no longer supported, and hackers will be looking for these machines to infect. I recommend you get a newer machine. The hard drive may be failing, or just the OS or hard drive corrupted. You could try this... Pull the hard drive out, and use a USB Hard Drive Adapter to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive.
Jun 29, 2014 | HEWLETT-PACKARD Computers & Internet
Format a xerox 250 hard drive
Sometimes you can format it on a windows or linux based machine to the correct format for the printer. You will have to find out which format it expects.
If it says initializing for an extended period of time, it is most likely formatting it and you just have to wait.
Make SURE you absolutely destroy the old hard drive completely. It contains copies of everything you have ever copied..
Feb 19, 2013 | Xerox Computers & Internet
How to slave the hard drive
You must go to BIOS setup and follow the steps.God bless youHowever follow this steps:
Instructions
Remove the screws on your computer case and slide the cover off of the machine. Notice the hard drive bays in the front of the machine. The existing hard drive is installed in one of these bays.
Use the tweezers to set the jumper pins to "Slave" mode. The jumper pins are white connectors located on the back of the hard drive. Above the jumper pin section on the hard drive is the schema to set the drive to "Slave."
Insert the hard drive into the computer case bay underneath the existing drive. Screw in the drive and mount it to the case using the screws included with the hard drive packaging.
Connect the hard drive cable from the main hard drive to the secondary slave drive. There are two connectors on the hard drive cable. The very end of it is inserted into the main hard drive. The middle connection is used for the slave drive. Insert this secondary, middle connector into your newly installed drive.
5
Insert one of the power supply cables into the back of the hard drive. This supplies electrical power to the device.
6
Replace the case cover back onto the machine. Ensure you replace the screws to properly fasten it to the computer case.
Jan 23, 2013 | HEWLETT-PACKARD 500B MT E5700 3202GB 27 PC...
Can i take my portable hard drive from my hp desktop and connect it to a mac?
Hello Leean,
You can take the portable hard drive from your HP Desktop. But when you connect your hard drive in Mac machine it will not recognize it. Because the hard have NTFS partition and the Mac operating system will only recognize HFS & HFS+ partition.
You can only use the NTFS partitioned hard drive on Mac machine if it have Parallels OS. Parallels allow you to connect your NTFS partitioned hard drive in mac machine.
Oct 13, 2011 | Computers & Internet
My mac is reading my transcend storejet 25 mobile 320gb, but i cant copy files from my mac unto it
Hello Kinoshia,
It seems that Transcend external hard drive have different file system. This is because the Mac machine is not able to transfer the files on to external hard drive. Please format the Transcend external hard drive from Mac machine and then hard drive is ready to accept the data from Mac machine. The drive either has to be formatted for Mac( HFS & HFS+) or FAT32 partitions. If you want to use
Transcend external hard drive for both Windows and Macs than format the drive to be FAT32.
Jun 05, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Picture freezes
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it. If it works with the hard drive removed then you may have a faulty hard drive m8. To test your machine before you buy another one, borrow a mates hard drive and test it in your machine, if you get the error code again then something in your machine is faulty. If it loads ok with a different hard drive then yours is definately the problem. www.fixmyconsole.co.uk
Jan 25, 2009 | Microsoft Xbox 360 Console
New 160 gig hard drive, can't load XP on Fujitsu S6210
Insert the new hard drive in your laptop, boot up and go into the BIOS.
Check if the hard disk setting is set to Auto (detect). Check the system configuration and see if it detects the hard disk.
If there is a hard disk diagnostic utility within the BIOS, run it to check the hard disk.
You can also test the hard disk by booting up with a boot floppy disk, run fdisk.exe to see if can display, create a partition, and format the hard drive etc.
If not of this works then it is highly possible that you have a faulty disk controller in your laptop.
Dec 18, 2008 | Fujitsu S6210 Notebook
E-MACHINE T5248
how old is the machine???
what kind of hard drive??? IDE or SATA
the newer machine do not need hard drive configuration. but not the old one.
configure the old hard drive to "master" and the new hard drive to "Slave".
go into BOIS and make sure both hard drives are being detected by the machine.
Oct 19, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
15 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
