Lights come on, no fan or sound of the cpu actually firing up.
Open your pc panel, look for the heat-sink fan over your cpu(processor). there is a small fan over it and if it is not spinning your PC will not boot. could be a wiring issue where the wires(white/red usually) are broken or not connecting to motherboard good enough. check those but be careful no to break wires or connections. you may need to replace the heat sink module. if any capacitors on motherboard are swollen(little cylinder looking objects with + mark on top) will indicate overheating and motherboard may have failed. if fans spin on heatsink, then pc boot file may be damaged where then a shop will cost to fix it. fans will be the cheap fix else$$$
i had just solved this problem yesterday, there
this symptom below please checked.
1.won't boot after power on button 2.LED on motherboard is light
3.unable to BIOS setting screen 4.CPU fan doesn't work
How to solve
How to solve
1.Please find this IC on
motherboard EPU
asp0800 near the CPU Socket
2.Press the IC with finger,at the
same time press the power buttom
(If CPU fan is running on short time please do step 3 )
3.Power on your soldering iron and contact each side of this IC about 3 seconds( soldering iron to contact IC lead left to right or right to left)
4.Review each side of IC and check any short between IC lead5.After step 4 done, power on pc again, if PC booting congratulation
6.Final check: put finger on ic top side
surface (don't touch the IC lead)feel the temperature if too hot that's mean short between IC
lead,please
rechecked step 4
