Question about Fuji MX-1700 Zoom Digital Camera
Fujifilm mx 1700. I am getting a ''card error.''
How do I fix it? I have replaced the card and removed the battery.
5 Suggested Answers
rajdeepdutta
  • 2517 Answers
SOURCE: Hello.When I switch on my Fuji MX 1700 'card
Hi there ,
remove the card clean the card pin and card slot in cam by a napkin. then try . if the same msg come then format the card and try again. If again same msg then change the card use new . Becouse every card have a limited snaps. For exam : 0001 - 1999 is life time camture capacity. if your full fill then the camera shown card error. Becouse when a card manufaturing the company fixed a total use capacity, so if that cross the msg with come that CARD ERROR.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Posted on Jan 31, 2010
Steve5
  • 423 Answers
SOURCE: Card error with compatible memory card (Z30fd - Fujifilm)
Try doing a "format" of the card through the set-up menu.
Posted on Aug 08, 2009
  • 11967 Answers
SOURCE: I inserted a 2gb memory card into a fujifilm
It wants you to format the card in the camera. This will erase it so if there are any pictures on it, download them first using a card reader if necessary. Then, go into the menu and find "format"...follow the on-screen instructions.
Posted on Sep 13, 2010
muntejaya
  • 10421 Answers
SOURCE: I need a cable from
Hi, You can find firewire at here :
http://www.amazon.co.uk/ABC-Products%C2%AE-Fujifilm-Finepix-Digital/dp/B000MX4SLM
Regards,
Posted on Dec 17, 2010
How to remove card error in fujifilm jz300 camera
Welcome to FixYa.
The reasons why do you get a message "CARD ERROR" are:
1. The memory card is not formatted.
2. The memory card requires cleaning or memory card is damaged
3. Incompatible memory card.
4. Camera malfunction.
What do you need to do are:
1. Format the memory card.
2. Clean the contacts with soft and dry cloth. If the message is repeated, format the memory card again. If the message persists, replace the memory card.
3. Use compatible memory card.
4. Contact FujiFilm dealer.
Feel free to send us your comments and suggestion fi this solution was helpful.
Thank you for using FixYa.
Apr 11, 2011 | FUJIFILM FinePix JZ300 Digital Camera
Fuji finepix s800 lens error message
Hello and welcome!
The most common cause for a Lens error:
  • Misaligned Lens rings
  • Sand and grid wedged in between the lens and the barrel.
  • Dropping the camera
  • Ran down battery
The following solutions are there by which you may Fix the lens error
  • Firstly you can try removing the batteries and replacing it with a new set of fully charge ones
  • If the batteries ran down while you were taking photos with the lens extended, you might also get this error. Remove the the memory card and replace the batteries with a fresh recharged set. Try to power on the unit with the fresh set of batteries while the memory card is removed
  • Connect your camera to your computer using your USB DATA cable which came with the camera. Once the camera gets power in this mode, the screen should stay off, hence, supplying the lens with more power to push or pull out/in
  • Place the camera on a sturdy table with the lens pointing to the ceiling. With a fresh set of batteries installed(Do this without a memory card) hold down the shutter button while you power on the unit
  • Now, you can either use a compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or, you can use a vacuum and and carefully place the nozzle around the lens to out the particles
For more solution by which Lens error can Recover Here you Go. It will help you out more briefly
if further assistance required, I am here to help.
I hope this solution helps you
Thank you for using FixYa!
Apr 08, 2011 | FUJIFILM FinePix S800 Digital Camera
I got the fuji mx-1200 and i need a memory card, which one does it take?
It uses SmartMedia cards from 2MB to 128MB in size.
http://www.fujifilm.com/support/digital_cameras/compatibility/card/other/
Feb 02, 2011 | Fuji FinePix MX-1200 Digital Camera
Hi there ,
Jan 31, 2010 | Fuji MX-1700 Zoom Digital Camera
Screen says card error
Fujifilm FinePix E550 Card Error Problem: With camera OFF, remove XD card. Turn camera ON & "take" a couple of pictures. Turn camera OFF & reinsert the XD card. Turn on & it should be good to go. It sems strange that this info is not available on the fujifilm website where they suggest to take the camera to "the nearest authorized FUJIFILM repair facility."
Oct 02, 2009 | Cameras
Jun 07, 2009 | Fuji Finepix Z20fd Digital Camera
Bought graphics card upgrade yet will not detect
The board should recognise this card ,however connect card with pc off and reset your cmos jmper hold for few seconds or take battery out,replace boot up get into bios ,normally delete button,reset your time and date and save try reboot
Jan 14, 2009 | ASUS P5VD2-MX SE Motherboard
Frame error
Backup the photos already on the card, then format it in the camera
Jul 10, 2017 | Fuji MX-2900 Zoom Digital Camera
Fuji MX-1700 Zoom Digital Camera Logo
52 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
