Mitsubishi VS60603 Signal Board
Noticed your comments on other Mitsubishi parts. Do you have a source for a signal board part# 930B827014?
Thanks
  • 8,617 Answers
No thats been discontinued. I do have a source where you can get your board rebuilt. Its
http://servicemanuals.vstore.ca/
Posted on Nov 23, 2008
Mitsubishi WS-65907 rear projection TV HD goes blue.
I would look at the source for the Hd signal as being the problem--if you are using some kind of cable or sat box it will deliver the signal to the DTV input on the back of the set--this is the HD input for this set.
It is possible to have a problem like you describe be one in the set--but very unlikely----have you looked on that green signal board for any signs of Glycol?
Anything that will produce a 1080 signal to the DTV input should tell you if the problem is the set or the source of the HD signal that is causing the problem.
If you have questions or need advice let me know--I am here to help people.
if this information has helped you rate this solution as i do this here for free.
SD TECH
Dec 05, 2009 | Mitsubishi WS-65907 65" Rear Projection...
Picture bows and shadow
Hello, asnowman here.
I had to reply to this post, as the other would not let me.
Your question:
Comment posted on Oct 26, 2009 Thank you for your help, do you know what board this is on? signal, main, or power? Your televsion is the 73411, and I think that your convergence IC's are on the center board, (called the power board, even though it doesn't have the flyback on it), if they are not they are on the signal board. You can't miss them they are attached to a very large aluminum heat sink and the IC's are very large as well. I hope that this answers your questions. If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Oct 26, 2009 | Mitsubishi WS-73411 73" Rear Projection...
VS60603 Does not turn ON - Also a STK392-570 problem? or 0244211
The STK392-570 would be the big IC's mounted to the heat sink on the convergence board. The 0244211 are capacitors that I would guess from your problem would be on the power supply (usually the top will bulge if these are bad)
Aug 13, 2009 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi WS65807
The Color Signal on this Model Series travels across three boards before being sent to the CRTs. The 3DYC Board, Signal Board and the Terminal Board. Most likely, the 3DYC Board or the Signal Board is causing the problem. I have had intermittent solder connections on the 3DYC Board to cause no color problems. This Board plugs in and is located on the left front of the Signal Board as you look from the rear of the chassis. If you feel you are not up to the task to work on the set, call a Mitsubishi professional. To find one, call Mitsubishi at 1800-332-2119.
I hope this helps,
Skyassoc
Jul 24, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi VS-50705 50" Projection TV
I jus posted a response to tell you where else to look for that liquid as its most likely the CRTs leaking.
Jun 14, 2008 | Mitsubishi VS-50705 50" Rear Projection...
SIGNAL BOARD
Hi, Any authorized Mitsubishi dealer can order your board for you, If you live in a metro area go to Sears Service dept.(not the stores) and order one there, Mitsubishi is "proprietary parts" so you have to go to an authorized dealer, hope this helps you out, BMW Rider
Jan 14, 2008 | Mitsubishi WS-65819 TV
Woodgrain effect lines on picture
Dont know if youre still looking for a signal board or not but this site has one. I hae used this site numerous times their products are great and prices cheap.
Dec 17, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Mitsubishi WS-55908 Convergence Issue; need IC 7A00, Panasonic MN12857k MA2
Sorry, but when the coolant leaks down onto the small signal board, that board will never work right again. The fluid penetrates the board itself since the board is double sided and has many feed-throughs. The fluid gets under the surface mount parts and just eats through the copper traces, part leads and board itself. After trying many times to clean and restore those boards, not one has ever worked right again. The boards are NLA from Mitsubishi, so the set is done.
Aug 30, 2007 | Mitsubishi WS-55908 55" Rear Projection...
VS-60703 signal board needed
if you want to sell the convergence board, i will buy it warlord069@gmail.om
May 30, 2007 | Mitsubishi VS-60703 60" Rear Projection...
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
