I just installed a new solenoid valve on Aprilaire humidifier. When the furnace shuts down after the temperature in the house reaches the thermostat setting, the humidistat does not turn off and water continually runs through the valve into the tray.
-   I have a similar problem on an Aprilaire 550. I have not solved my problem but can help you identify the source. On my unit a humidistat, the solenoid valve, a 24 volt transforer and a current relay are wired in series. In theory, when the thermostat calls for heat, the furnace exhaust fan cuts on, the burners then cut on, then the fan cuts on. If the humidistat calls for humidity, the water valve solenoid cuts on when the fan starts, assuming that the relay senses current going to the fan. When the temperature is reached, the furnace and exhaust fan cuts off. However, the fan continues to run for a time until the heat exchange box cools down. The fan then cuts off as does the humidifier since there is no current flowing through the wire to the fan.
Potential solutions:
1. You didn't wait until the fan cut off to see if the humidifier shut down.
2. Since you replaced the solenoid, the problem must be in the current relay sensor. Move it around and see if the humidifier cuts off. If it does, the relay was picking up current from another source or was stuck. If it doesn't cut off, it is probably bad.
I did all of this and put in a new current sensor but it did not solve the problem. I believe the new part is bad but am not sure.
Let me know what you ultimately found. -   Guest
Mar 08, 2009
-   I have the same problem with the unit. It will not shut off after the furnace stops running. I replaced the solenoid and that didn't help.
Can you answer on this one? Would I need to replace the humidistat?-   Guest
Nov 25, 2008
-   I had the same thing happen to me today. I installed a new solenoid valve and now the water does not stop running when the furnace shuts down.-   Help welcome
I have a Lakso model 110 humidifier that needs a filter. Can you advise me where I can find...
(More)
I have a Lakso model 110 humidifier that needs a filter. Can you advise me where I can find one?
Karen Pankratz
pankjp@comcast.net
Hi, Could anyone please recommend filter free cool mist humidifiers (3-4 gallon). I am sick of...
(More)
Hi, Could anyone please recommend filter free cool mist humidifiers (3-4 gallon). I am sick of replacing hard to find filters of my Holmes humidifier.
Thanks.
Will Super Wick Model #1045 work on my Bemis 497-300? The filter box says it is for Bemis &...
(More)
Will Super Wick Model #1045 work on my Bemis 497-300? The filter box says it is for Bemis & Essick H12 series humidifiers, but I can't find what Bemis models are in the H12 series.
