Question about Sharp Twin Energy EC-T4660 Vacuum
It won't ****!
My Sharp is not sucking very well...like it is reversed....can this be? I just replaced the bag, so it is not that....
  • Susan Berger Nov 24, 2008
    I already looked at the belt...it's fine. Thanks anyway!
  • 55 Answers
Try turning it on and looking at the spindle to make sure the belt is not broken and it is spinning.
Posted on Nov 23, 2008
How do I clear a blockage
Try removing your hose from the bag housing (pinch retaining ring and pull out) and re-inserting in reverse order. Turn the vacuum on and suck the clog into the bag. This will usually clear a clog from the hose. If the clog is in the power head (base), you can usually access it from the top side of the swivel neck or the orange access door on the bottom of the chassis.
Sep 23, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Is there a switch that reverses from sucking air in to blowing air out
No there are NOT switch Normally this motor from AC, doesnot have this device for reverse. Only you can do it by open the motor and chaging the connections
Now you must shure the a) hose is clogged b) bag is clogged c) or there another thing maybe a sock. please use the common sense
However you can go to the web page from kenmore and see your instr. manual download:
http://www.managemylife.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu
Jul 27, 2012 | Kenmore 31913 Progressive Direct Drive...
Dust and air coming from back side of vacuum cleaner
the bag of ur vacuum cleaner is full. thats y it is happening...
clean the bag of ur vacuum cleaner.
n check is there any blockage in the vacuum pipe, if any then remove that.
Oct 29, 2011 | Sharp Vacuums
My Kirby is blowing out not sucking in how do I change this?
Either there is a blower option on the vacuum cleaner that needs to be set back to where it belongs, or somebody changed the brushes on the motor and got the brush or field wire connections reversed (one or the other, but not both).
Oct 23, 2011 | Kirby Ultimate G Bagged Upright Vacuum
I have a sharp twin energy, the hose isn't sucking very well, and just today it had a burnt plastic smell
This sounds like something is plugging the air flow. You need to take apart until you find it. Air flow also cools your unit.
Jun 09, 2011 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Kirby g2000 not picking up dirt
It is most likely the belt. You cannot reverse the suction. First check to see if the bag is expanding when running. If the bag is blowing up then it is the belt if not it is clogged just take the bag off from the vacuum and remove the head you will see the obstruction.
Dec 16, 2009 | Kirby G6 Bagged Upright Vacuum
Blowing out?
Did you check the inlet down by the brush roll?
Feb 13, 2008 | Bissell 3522 PowerForce Bagged Upright...
Sharp Twin Energy EC-T4660 Vacuum Logo
142 people viewed this question
Top Sharp Vacuums Experts
jasbo
jasbo
Mike
Are you a Sharp Vacuum Expert? Answer questions, earn points and help others
