Pioneer DEH-P7300 CD Player Logo
A
Anonymous Posted on May 18, 2012
Turn off entertainment display on pioneer deh p7300
3 Related Answers
julian appleby
  • 149 Answers
  • Posted on Apr 21, 2008
SOURCE: ipod?
Get an ipod fm transmitter if you havent got any aux input
Anonymous
  • 47 Answers
  • Posted on May 13, 2008
SOURCE: pioneer deh-p840mp
THERE IS A RIBBON CABLE THAT CONNECTS THE FACE PLATES TO THE RADIO THAT NEEDS TO BE REPLACED
mikehumble
  • 124 Answers
  • Posted on Dec 27, 2008
SOURCE: how do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
I have the pionner deh p7300 i want to hook up a ipod i have a sub woofer and amp. on the back of the headunit i have rca plugs for the amp in the rca plug on back of unit. the there are 2 other sets of...
Buy a rca to aux 3mm plug then you can connect to aux port.
RCA out is for the signal to the amp from the Head Unit. Mic is probably for your cell phone.
Am pretty surprise that an HU like that doesn't have USB Ipod support?
1helpful
How to set clock in pioneer deh4000ub
here is the link for your manual:
http://www.pioneer.co.uk/uk/support/manuals/DEH-4000UB/index.html
Setting the clock
This function is available only for DEH-4000UB.
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Turning the off clock
display on or off
If the off clock display is turned on, the clock
appears on the display when the sources are
off.
OFF CLOCK.
2 Press MULTI-CONTROL to turn the off
clock display on.
# To turn the off clock display
Cheers!
1helpful
How to adjust brightness pioneer deh-546?
Turn unit off. Hold function button until options display, including tuning steps and display brightness.
37helpful
How do I set the time on a Pioneer DEH-P3100UB
Press and hold SRC until unit turns off. Press MULTI-CONTROL and hold until CLOCK SET appears in display, then release. Press MULTI-CONTROL to select Hour or Minute. Turn the MULTI-CONTROL knob to change segment that is flashing. Reference page 26 in this link to Pioneer for your DEH-P3100UB instruction manual.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-P3100UB_OperationManual1029.pdf
I hve a DEH-P7300 and the screen dies randomly and comes back on. Sometimes it will be fine for an hour, then dead for 2 days, back and so on... What can it be?? Thanks
This is a cable issue from the faceplate connetor to the main board on the unit. This is a common issue with these units the cable runs around 15 to 20 bucks
Ipod?
1helpful
Display
go into your tools menu by pressing the center of the multi knob.(the volume control knob) turn same knob to bring up the entertainment field, press center of knob to set then turn till you get to the prompt about alternating screen. switch to no. done.
How to turn off alternating display.
turn off the unit and push the entertainment button or the display button it will beep once flashing stops lol i had the same problome im not sure what button it is thought doesent hurt to try them all its the second one on the bottom of the unit under the display but the unit has to be off
5helpful
3answers
Display
One of the replies from another 'helper' hit it on the money with a different model. You need to press & hold (in off position) the # 6 button for demo. Once the demo starts, a choice for inverted display will suggest to press #5 to turn off or on. At that time you will be able to correct your problem as I have. I had to do it twice because I was driving at the time, which I don't suggest , when I remembered the advice , lo and behold, it worked . Thank you other replier for that tip.
Pioneer DEH-P7700MP
hey, either the face plate isn't getting good connection with the unit so you need to clean the connection gold plates or your just on a blank screen and you can fix that by pressing the knob in until the screen says Entertainment, then scroll thru the possible screens until you choose one you like.
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
