Question about Sharp VC-A410U VCR
VCR playback has a large black square on the bottom of the screen
My Sharp VCR had been working well. However, yesterday we tried to play several tapes and in every case there was a large black rectangle in the center of the bottom of the screen, measuring about 10" wide and 4" high. When I fast forward, the box disappears.
  • 180 Answers
Check the guid post alignment.
Posted on Apr 04, 2008
Our Sony Video cassette recorder model SLV_N750 won't play??? The tape is going into play, but the reels are not turning. The VCR starts with a snowy picture and guickly stops and won't play?
The problem is the idler assembly or the black square belt that drives it, this will cause the vcr to shutdown preventing tape transport. The vcr will need to be dismantled for repair, I recommend a tv technician to check your machine with an estimate.
Jan 08, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
Sansui DVD/VCR remote control issue, VCR works/DVD does not-black
There should be a DVD/VCR button on the remote control which will toggle the machine from one playback source to another. If she has pressed the VCR button then the machine will only playback tapes & not show DVD's. Press this button & the DVD's should play. If you look closely at the front window of the machine it will show what mode it is in ie VCR or DVD, set this for the DVD to get it to play.
Sep 16, 2009 | Sansui VRDVD4000 DVD Player/VCR
Picture problem with DVD and VCR
Make sure the text box function of the closed caption decoder on your tv is turned off.
Oct 30, 2008 | Pioneer DVR-RT300 DVD Recorder/VCR
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Black screen
I have a Sharp Tv that had the same problem with a large brownish or black square right in the middle of the screen. It only left about an inch around the edges that you
could see the picture moving in behind the big black block or square.I have DISH sat-elite and the book recomending that I check and see if the "caption settings" were on
or off. They were on. I turned the caption settings off and the large square diappeared.
Nov 18, 2007 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
VCR Play Back is OK, but Recording produces Blue Screen on playback
If the heads are TOO dirty, a head cleaner will not help. If you are cinfident enough to open up the recorder, then they can be cleaned manually.
Disconnect the VCR from the mains.
Remove the screews from the side and back (if applicable) of the lid.
Remove the lid.
Look at the large drum (set at a slight angle) If you gently rotate the drum you will see 2 or 4 small sensors set into the drum.
Tear of a clean piece of A4 paper about 1inch square.
Hold between thumb and first finger and rub the centre of the paper against each sensor in turn. Make sure the edge of the paper does not catch the sensor.
After each sensor check the paper for dirt (black marks) and change paper if need be.
Try a recording / playback.
Repeat if necessary.
Nov 08, 2007 | Philips VR330 VHS VCR
Can an adaptor be used to play my 8mm tape in my VHS VCR?
With the Sharp Viewcam ®, there's no need to use an adaptor to play 8 mm tape. Simply connect the Viewcam ® to the TV or VCR for playback. You can even use your VCR to make a copy onto VHS tape.
Sep 07, 2005 | Sharp Viewcam VL-A10U Camcorder
Sharp VC-A410U VCR Logo
316 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
