Question about Epson Stylus C86 InkJet Printer
Epson dx7400 printer - ssc reset available?
My dx7400 seems to have given up, all lights are flashing, Ive just heard that some printers can be reset, where can I find this utility for the dx7400? Id be so grateful, thanks, claire
  • imaginefuncl Nov 23, 2008
    Ive tried it but no DX's are listed and using 'unsupported' doesnt help, thanks anyway xx
  • Anonymous Feb 15, 2009
    I HAVE THE SAME PROBLAM BUT I HEARD YOU "CAN" RESET THE DX7400. I HOPE SOMEONE HELPS !
  • Epson Master
  • 541 Answers
Posted on Nov 23, 2008
Cx7800,epson
All lights flashing isn't something you can "reset". Are the lights flashing alternately, or together? These are different errors.
Alternating means that the printer thinks the "waste ink pads" are filled and need to be replaced (costs more than a new printer). You can reset the counter, but then you run some risk that the waste ink will overflow your printer onto the surface where it sits. messy.
The SSC utility will help you reset it if that's what you want.
SSC Service Utility for Epson Stylus Printer
Apr 13, 2015 | Epson Office Equipment & Supplies
Epson stylus dx7400 will not work with ciss - lights keep flashing
this mean that the waste pads full and you need software to reset the printer
Feb 11, 2013 | Epson Stylus Office Equipment & Supplies
I need reset software for epson cx3600 as i have two red flashing lights and flashing E
The SSC utility will allow you to reset the waste counter on this printer... You may find that this is a general error though in which case resetting won't make any difference.
Link for SSC:
http://www.ssclg.com/epsone.shtml
Jul 27, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Green and red light flashing
SSC Service Utility allows you to do many things to your Epson printer, Work directly with CSIC in Epson Stylus printers cartridges, Freeze internal ink counters, Reset internal ink counters even with empty cartridges, Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode, Hot swapping of cartridges supported, Resetting of protection counter (even then it is already full), More then 60 different Epson printers supported This allows many people with high printing demands to save money (program works with both black and color cartridges).
May 12, 2009 | Epson Stylus C43SX InkJet Printer
2 red lights flashing service required
press maintence power and the small ink button all at the same time this will reset the printer
Apr 05, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epson 2400 paper red light and ink red light
It sounds like your printer has reached what is often called the "service required" stage...
To solve this you need to handle two things.
1. Get the printer protection counter (or waste-ink as it's sometimes called) reset.
2. Replace the waste ink pads OR redirect your waste ink flow to an external tank
It's important to note that Epson will encourage you to do a waste pad replacement through one of their service centers, but if you're out of warranty this will cost a significant amount of money (approx: $100 - 200)
To solve these as a DIY you can do the following:
1. Resetting the counter...
Get a resetter, either the SSC utility (google: epson SSC utility) or the IPR utility that Epson have now made available via their website here
The latter is only available to North American printer owners so the SSC is a safer bet.
2. Redirecting waste ink to an external container.
This is something I'd heartily recommend instead of trying to change the waste pads yourself... It's simple enough to do and a little googling using keywords "Epson R2400 waste ink tank" should get you all the info you need.
There are simple kits available that offer everything you need or you can easily go for a DIY with bits you have to hand.
Hope that helps...
Mar 07, 2009 | Epson Stylus Photo R2400 InkJet Printer
Power light and red light keep flashing alternatively
If both lights are flashing alternately, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utilit to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Nov 03, 2008 | Epson Stylus 680 InkJet Color Printer
SSC service Utility for Epson DX7400
I have replaced the cartridges , the chips have worked , the printer goes through the cycle but does not print but the ink is going down
Sep 22, 2008 | Epson Stylus C86 InkJet Printer
Epson r265 sevice require
how much for a new waste ink pad in the uk ta
Aug 10, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus photo 810/ink jet printer
Hi Alan
I expect by now you've solved this problem - but just in case .....
The waste ink "protection" counter has exceeded its limit and needs resetting. You can do this easily by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (810), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
May 17, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus C86 InkJet Printer Logo
7,118 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
