Question about Falcon Barcode Scanners
1996 EL Fairmount 6 cyl auto
Wil not start, turns over, plenty of spark and fuel, but if key is left on for 30 minuites it will start first go and run as sweet as.
    Scholar:
  • 126 Answers
Sounds like it may be the points in the distributor? Have you had them replaced since owning the car?
Posted on Nov 23, 2008
Mc9090 laser stops working switching between sessions
Same here. Just started happening w/ scanners coming back from the EL PASO repair facility. Performing a "Clean Boot" on one running WM5 seemed to correct this issue. BUT, we have two other units w/ this problem that are running WM6, and the clean boot did nothing to help this.
Mar 13, 2012 | Symbol MC9090 Barcode Scanner
I am unable to locate the ESC key Could you please help. New device
What kind of device is it? A normal keyboard has the ESC key in top left corner.
If you are using a Windows device run the "On-screen Keyboard" and click the ESC key with your mouse - better than nothing. (Find the on-screen keyboard in the Start Menu under Accessories - Ease of Use)
Aug 04, 2011 | Barcode Scanners
The computer tells me the hardware radio switch is turned off on my ASUS U52 notebook. But I can't find out where/how to turn it on.
The radio switch key is the 3rd key from left top row, all top row keys are function keys. To activate the function on the keys you need to hold down the function key, located bottom row 2nd from left (fn) key. Hold down the fn key and press the radio key. That will switch the radio off and on.
Dec 07, 2010 | Barcode Scanners
What do i press to be able to access the green symbols above my keys on a sharp EL-531VH
I can help you with your Sharp EL-531VH Scientific Calculator problem.
To access the symbols above the keys, press the '2nd' button first, then the button with the symbol you want. On my calculator the secondary functions are in orange, not green, but I suspect it is the same deal just a different color.
I have a digital copy of the manual for this unit - I will update this solution with a link after I have posted it to fixya.
I hope that helps.
Sep 26, 2010 | Barcode Scanners
I cant start my computer! when i press the power button my monitors light turns orange(from yellow) and my keyboard's light starts blinking...there comes a beep sound three times,my CPU power light remains...
This means there is some issue with your computers RAM sticks, Open the CPU and refix the RAM sticks .If you have multiple RAMs in system try to fix one and start computer.Still not working remove that RAM and fix another one. even its not working you will have to change RAMs.
Aug 12, 2010 | Barcode Scanners
Re-set key on the Motorolla MC9090 RF Scanner
Take out the battery, press and hold the power button and trigger for 30 sec and push back the battery the release the buttons.
Jun 30, 2010 | Zebra Symbol Technologies MC909X-G Series...
Battery backup I have a server running 750watts powersupply, has intel xeon 1.6 (2 x quad core) 2 scsi drives, 4 SATA drives and 4gb ram. Will 1300 watts battery backup be enough?
I have a similar setup on my Small Business Server and an 1100 Watt backup. It will run my server for 30 to 45 minutes and sends the signal to shut the server down when power gets critical so my server will do a clean shutdown. I've replaced the battery once in 3 years so I would say the 1300 Watt UPS will be sufficient to operate your server for a short period of time before doing a clean shutdown. (You may get an hour or so out of it before it shuts your system down). Be sure it has either a serial or usb connection to keep your server apprised of its status.
Mar 05, 2010 | Barcode Scanners
TELXON 610 frozen
Hi Tanya,
That is the base TCAL operating system, version 6.7. You can reset it by
  • turning the hand held off
  • holding down the bottom left and right buttons
  • switch on and holding down the on/off key till it reboots.
If it still comes up with 67> then try [6] and then [Enter] key. This lists the applications they will end it .y then hold [5] to run.
If nothing works then either the ARC is faulty or application was RAM loaded and has been lost.
If you need any further assistance then please contact us
www.biastechnology.com
helpdesk@biastechnology.com
Jul 13, 2009 | Symbol Telxon PN: FlatRepair-PTC960X-LVL2...
NCR 7875 SCANNER/SCALE
Hello
Well regarding this error sending you this display of the scanner in most cases is needed because if the scanner calibration, you have to do is:
Remove the dish from scanner (where you put the products to weigh), there you will see that has a plastic part on the right side, and take away that the bottom is a black button color you need to start to put pressure gauge.
Once you press this button, and is ready to start calibrating, then put him back to the plate and the scanner with a voice that sends you will be asking some weight, so this should have on hand your weights to calibrate the scale.
First the scanner asks 0 kg. in this step not going to put anything in weight, ahi press the button Scale Zero appearing in the panel's scanner,
After asks you to 2.5 kg, is there when you need to put the 2.5 kg asks you, when you have them placed on the plate press Scale Zero, the scanner then will ask now that you put 5kg, then you take away those who had 2.5kg and you put the 5kg, and when you have 5kg in the dish press the button Scale Zero, now the scanner will ask that you put 10k, then take away the 5kg and that he had put the 10k that asks you to press the button and Scale Zero, and finally asks you to the scanner in this 0Kg, then you take away the 10k and leave it with nothing, and press Scale Zero
If the calibration did well Scanner you send a voice message that says Calibration Complet or calbración completed, it is very important that when you calibrating the scanner is not moving or having obstacles that may make the calibration is not made well, good clean plate and that this part of the bottom, which revises the 4 Gomito that has to sustain the plate are complete, that are not broken up or are some more than others and that when you put the dish did not move. fijate also not hit the plate or the chassis of the scanner with something else, so there's no obstacles in the calibration,
If you salio calibration is not well in the display will show a 9Error, this means that there was interference during calibration, it is required to check well before the scanner or do a cleanup.
Feb 21, 2008 | NCR 7875
Barcode Scanners Logo
69 people viewed this question
Top Falcon Barcode Scanners Experts
Brian Sullivan
Brian Sullivan
Gareth Cockram
Gareth Cockram
Are you a Falcon Barcode Scanner Expert? Answer questions, earn points and help others
