Thermostat in motorhome quit working
It is lit up, but cannot change any settings, can't select zones, and heater/ac is not working now at all apparently because the thermostat is no longer controlling it. It worked last night, but quit sometime before daylight.
It is a heat pump/AC system by RV Products, a division of Airxcel, Inc. Thermostat is by RV Products and is called a 8330A335 multi zone thermostat controller system
    Sergeant:
  • 359 Answers
Try removing power from t-stat and leave off for one minute and power back up see if resets
Posted on Nov 24, 2008
Problem with AC thermostat
You are correct about the "er" message. Best bet is to check your user manual for error codes and then take it from there. If nothing in book it is possible that the answer might be on manufacturer web site.
Could be issue with thermostat itself if the other zone is being cooled properly.
Aug 05, 2016 | Heating & Cooling
Installed an rth2510 and installed as labeled on old stat and sounds like my ac nut is buzzing outside, any thought?
question: do you have a multiple thermostat setup in 1 zone? If so check what settings are for your heat on each thermostat. Make sure that the heat is not set higher than the room's temperature.
check what settings are for your cooling on each thermostat. Make sure that the cooling is set accordingly.
if you have multiple thermostats setup in 1 zone. the thermostat with the lowest temperature will reign supreme. The heat setting on that thermostat will be what's causing the buzz on the heater.
optionally, hard reset your thermostat as a precaution. Here's how to do so: there are two types of thermostats i know of programmable and non-programmable.
disable auto & enable manual; however do NOT change settings or power-off t-stat. Remove battery and power down the thermostat until you see nothing on the thermostat monitor; power OFF the switch connected to your t-stat. Remove battery and reinsert inverted, if needed, press whatever button that your heart desires to make sure that nothing is absolutely drawing into that mode, button, etc; wait (5sec-1min); remove batters; wait 1min; then, reinsert batteries in its correct position; if you have a programmable thermostat; do the same with the hit 'reset filter' held down observe if the roomTemp reading has changed.
May I suggest to keep an extra thermometer around to determine if temperature reading accurately?
If reset requires a reprogramming to your t-stat, do whatever required to set your desired setting.
cheers, best of luck. i hope i've helped.
background, doing a hard reset in my opinion is similar to removing the battery from a PC motherboard.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
AC fan runs when heater is turned on in RV Dometic single zone
the heat and cool use the same fan. if compressor is running with heat then you have relay issue
Jul 05, 2013 | Dometic 3313192.000 White Single Zone LCD...
No display on Robertshaw 9600; unit seems dead/furnace works
Hello
you have to have a thermostat! The thermostat tell the unite what to do. Get a new one.
Jul 25, 2009 | Honeywell Programmable Thermostat Heater
Heater does not blow hot air
you might need to change the thermostat.. when the thermostat isn't working correctly it prevents the hot engine coolant to circulate and give you heat.
Mar 01, 2009 | 1994 GMC Yukon
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
Heater will not stay lit on auto procom ml 300 blue flame
If you have an ML300HGA, it is a manual-control heater, which means you turn it on and you turn it off. No thermostat. It does not have an AUTO setting.
Likewise, the thermostat-controlled models do not have a Manual mode. If you have the ML300TBA, it has a thermostat and will turn itself on/off in order to maintain a room temperature.
On manual models, the numbers (if any) on the dial are heat output selections. Set the control to the highest heat setting and that's what it does until you turn it off.
On automatic thermostat models, the numbers on the dial are temperature selections. Set the control to the highest heat setting and the heater will continue running until it is 85-90 degrees, then shut off. Set it around 2 and it will maintain a temp of around 70 degrees.
All Procom heaters are either automatic (thermostat-controlled) or Manual. None are both.
Oct 05, 2008 | Procom ML300HGA Heater
Quit working
Based on the limited info.I have, it sounds like the heating element is not getting power. suggest visually inspecting the switch and thermostat for burnt wires. Also check the heating element for broken electrode.
Nov 08, 2007 | Comfort Zone CZ-530 Compact Heater
Heating & Cooling Logo
379 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
