Question about Amana Quiet Zone 12M12TA Air Conditioner
Blown fuse? i have a quiet zone - power does not seem to be getting to the unit after seeing a flashing '90' in the display screen. my best guess is that it's a blown fuse in the unit? any ideas how to proceed would be appreciated.
    Problem Solver:
  • 5 Answers
Is the display still showing anything? If the display is blank check outlet for power? If you have trip the circuit breaker, unplug the unit before you reset it. Set the controls to off. When the power is back on Trying running the fan first, then try the AC. The flashing may just be a max temperature reading.
Posted on Sep 24, 2007
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Apple cinema display 23"
Hello!
Please do and verify any fuse blownout in the inlet of the power from the wall, if it is not visible then maybe you open the the back cover and try to see any parts that has error or blown. you should replace it with genuine replacement parts. however it hard to do this by a novice tech, My suggestion is to bring the unit to the nearest service center maybe the unit got warranty service or else maybe its a cheap or resonable cost.
may this help!
best regards, melnavz
Mar 03, 2008 | Apple Cinema Display 23" HD Monitor
My dashboard light for 2002 Ford KA not working, even after replacememt
Could be the small bulbs in the speedo unit have simply blown over time . You just remove the speedo unit and they tun about 90 degrees to unscrew . They cost a few pounds and you can get different colours these days.
Feb 19, 2012 | Ford Ka Cars & Trucks
Problem with LG 42PC3D 42 in. Plasma Television, the sound is there but no picture i can hear a click when I turn it on but nothing happens. I opened the rear on the unit nothing obvious is visible ......
Hello Jacques,
This type of failure on this plasma is due to a defective IC that is mounted underneath the black heatsink located on the Ysustainer board. In order to isolate this failure to the Ysustainer board, I would suggest to check the fuses at location FS2 and FS3.
Here is more info for in regards to the Ysustainer board: REPAIR SERVICE FOR EBR31872801 YSUS BOARD FOR FLASHING DISPLAY TV NOT...
Dec 28, 2017 | LG 42PC3D 42 in. Plasma Television
After a thunder storm my roof mounted Carrier cooling/heating unit stopped working and now does nothing. Changed the time delay fuses and checked the circuit breakers and they seem fine. Is there a reset...
You may have a circuit board problem. Make sure you have power to the unit first. If you can, get on the roof take the access panel off to the electrical components. Most carrier circ boards have a flashing light display on the board itself. On the back of the panel you just took off should be a kiosk that tells you what the flashing means. If the light is dead, no color but you are sure there is power to the unit, the board is bad or there could be a fuse blown on the board. Most circ board fuses are a small 3 or 5 amp blade fuse mounted right on the circ board. I have seen many a carrier board burn out because of lightning. I hope this is not the case for you, as carrier boards are just a little expensive. Hope this helps you get some air back. Mark
Aug 01, 2011 | Heating & Cooling
When pluged in the On/Standby LED will light. When pressing power the On/Standby LED with flash then go solid but nothing apears on the display. I can select what speakrs to use (A or B). All the LED's...
Most likely the unit does not receive power from main transformer. Possible several reasons:
- bad power transformer
- bad main internal fuse 7-8amp. Bad fuse most likely because of one of the channel is blown and shorts the power, so before installing new fuse good idea to check all channels by meter or at least visually for burned parts
- bad power relay
- bad connection, cracked soldering joints
Jul 18, 2011 | Denon AVR-1602 Receiver
Amana Quiet Zone air conditioner 12m12ta
Try setting the Unit to run full out, set unit at 66* it maybe the lights flash to let you know the save ( power) is on ?. Otherwise look for the manual and troubleshooter page .
Jul 17, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
My sharp LC-20AV4U tv did not turn on when i plugged it in
The fuse is blowning because most likely when you plugged it it, it took a power surge. And the power surge blow a proection diode. As long as you opened it up... in the power section you will see a bunch of diodes. Get a multi meter and check these diodes out. Besides the diodes... you will see a transformer.... if you are looking at the unit with the fuse to the left... then look to the right of the transformer... you will see a transistor on a metal heat sink... that could have blown also.. if that did... then you should also check the diodes just on the other side of the heatsink too.
Good luck
Dec 16, 2008 | Sharp LC-20AV4U Television
Akai PDP4294
Repair service for power board B4K-50:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110646032176
As stated in the listing there please note that there are unique board components that are not replaceable...so depending on the failure there's always a risk that the board may not be recoverable.
Apr 07, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Amana Quiet Zone 12M12TA Air Conditioner Logo
217 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
