Question about Dell Ethernet Card Network Adapter
Dell Ethernet Network Adapter not being recognised
Hi all, I tried the solution to ping to see if the Ethernet Card was there,and it worked!
However Control Panel Device Manager indicates a problem with the driver - no driver files have been loaded.
Where can I find the driver files?
Thanks!
  • rjcockwell Nov 25, 2008
    Hello-Yes I have basically same problem.2 green lights on back but device. man. says unknown device-drivers not installed.Also when I try to connect to net says cannot detect ethernet card? TY4 help
    Novelist:
  • 151 Answers
I) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1:  Local Area Connection 1 or 2 or 3
        Network Cable Unplugged, Firewalled
        VIA compatible Fast Ethernet
        in this case u can download VIA network drivers....from internet..
                      or
       eg2: Local Area Connection 1 or 2 or 3
       Realtek RTL8139 Family Fast Ethernet NIC
       in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing              model no: RTL8139 through google search engine )
                                         (OR)
ii)        Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select                Network Adapters....
           but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the             correct Model NO: of VIA or Realtek....
            so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Posted on Dec 28, 2008
My dell 8300 keeps losing connection with the internet, the connection is good the ethernet light is red
1. Disable your windows firewall immediately or allow the firewall to permit the ping.
2. 127.0.0.1 is loopback address to ensure your network card is working fine.
3. Change the network cable with serviceable one.
4. Un-install the driver and reinstall with new one from OEM site
Jan 05, 2012 | Dell Ethernet Card Network Adapter
Network can send but not receive packets modem cable is okay on another computer ethernet card working okay. cannot ping to the internet. windows xp home
It says it's sending, but it's not. It's just trying. I'd re-set up the network. To help, go into the device manager and uninstall the network adapter and restart the computer. The adapter will reinstall and that may help solve the problem.
With the little info you have provided, that is about as helpful as I can get right now.
Sep 15, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
How do i know if i already have an ethernet card
From Control Panel, goto the Device Manager
Find Network Adapters in the list
Click on it. if you have ethernet card/network adapter it will be listed there.
Hope this helps.
May 12, 2010 | Dell Ethernet Card Network Adapter
Ethernet light at the back of the computer does not light up, also does not recognise cable.
Check the dell website for support and drivers for your computer. go to www.dell.com and put your service tag into the proper section.
You either have the wrong driver for your network card or the network card is not functioning. You need to be sure the card is seated properly in the card slot first.
Chedk the device manager to see if the network card is recongnized. Go to your My Computer icon, right click and go to properties and then the hardware tab.
Look under network cards and see if you card is visible and if the driver is loaded for this card. If the card is there, try to download an updated driver for your network card.
I hope that you find this information helpful, if so, please leave feedback for me.
Thank You,
Brian .
Jan 25, 2010 | Dell Ethernet Card Network Adapter
Have a dell dimension 8300 and the ethernet card is not working. any way to fix or purchase a new card. Also getting c.exe hs stop working?
c.exe is an infection ,u have to use any antivirus software to remove this and u said that the ethernet card is not working, check the lights on the card when you connect the ethernet cable , check the same light when you are in the bios, check it in the bios, if it is detected in the bios, try pinging 127.0.0.1 in the safe mode with networking. if its able to ping then the issue is not with the card. if the pinging fails in the above step then reseat the ethernet card.
Jan 11, 2010 | Dell Ethernet Card Network Adapter
Dell vostro 1510 ethernet is not working but through usb port is working
Your ethernet card might of receive too many collision and that will damage the card, and the usb port has not yet.
Nov 19, 2009 | Dell Ethernet Card Network Adapter
Ethernet on DELL 4550 with TP-link doesn't work
pinging 127.0.0.1 just tells you that your network card is operational and reacheable by your system.
I have a couple of suggestions - check them out and let me know what you found out.
  • Go to Network Connections / Local Area Connection / General Tab / Properties / Internet Protocol (TCPIP) (from the list)/ Properties. Are all settings set to "Obtain automatacally..."?
  • Is your operating system Windows XP Home or Professional (with Service Pack 2 installed)?
  • Have you installed the AirPort Utility software that came on the CD? (Check Start > All Programs > AirPort)
  • You have to have the software installed in order to setup the router.
  • What is your internet connection: Cable or DSL?
  • Take a look at this document "Designing AirPort Networks" which is also on the CD that came with the device. If you don't have it, here is the download (link). Go to page 25 and follow the instructions for PPPoE (if you have DSL service) or DHCP (if you have cable service).
Let me know how that works for you and if you have any more questions, just come back here and leave a comment - I'm happy to look further into that if this did not work for you.
May 27, 2009 | Dell Dimension 4600 PC Desktop
Dell 1525 , wireless adapter
Go to http://www.halfdone.com and download unknown devices to get the correct wireless card info.
Apr 17, 2009 | Dell Ethernet Card Network Adapter
Problem with my lan port
did you check the cable that is it working fine???
and the other thing does your network connection shows that the local area is unplugged if it shows then it is definatly problem with the wire or Connector.
Nov 08, 2008 | Dell Ethernet Card Network Adapter
Dell Ethernet Card Network Adapter Logo
323 people viewed this question
Alun Cox
