Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
Motorola Z3 cover won't stay open
When sliding open the z3 cover, it won't stay open - it slides too easily down so that I have to hold the cover open to make a call/text. When the cover is closed, if I turn the phone upside the cover will open on its own. Are there springs or some other devices that causes the tension on thephone cover?
  • Anonymous Jan 02, 2009
    My daughter is experiencing the same problem. In trying to reslove the problem I have found a replacement part for the slide. What you need is called a "slide board". Google - "Motorola Z3 slide board"
You juss need to get a new one! if it slides open that easy when you turn it upside down...then yea a new one needs to be suggested.
Posted on Nov 27, 2008
How to turn on a razr z3 motorola cell phone and I can't find a manual online
to turn on the razr z3 motorola cell phone use the red button , with the help of which we dissconnect the call .... press and hold it down for 2 to 3 seconds and it will turn on ..............
Mar 30, 2010 | Motorola Mobility ROKR E6 Smartphone
SCREEN HAS COMPLETELY GONE
you must replace the screen, prove this
Does the device have power? If so, reconnect to Motorola Software Update and perform another software update. If the device still does not power up, simultaneously press and hold the *-#-Power keys until the screen lights up. Connect to Motorola Software Update and follow the prompts display
Sergio
Apr 06, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Buttons do not respond
keypad circuit is the problem...change it!!
Sep 28, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
How to replace the motorola rizr z3 outer navigation slide small
http://modmymoto.com/wiki/index.php/Razr_v3_Full_Housing_Change
follow the steps given in this site... think it ll help u out to change ur mobile's housing
Feb 22, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
How to download songs to motorizr z3
You can get songs on your phone in two ways, Either Purchase online, or you can use a USB Data Cable connect to your phone, (Note when you connect your phone, shut down the motorola phone tools after it starts, this will simplify the process) If you have your Motorola Z3 Drivers installed you plug in your phone, you will see a notice that a new Flash Drive or USB mass Storage device is connected. Open My Computer, then go to the folder containing the music you would like to install on you phone. Now open a second My Computer Screen and select the Drive Letter that represents your phone, this should be the highest letter alphabetically. Open the "mobile" folder, then inside that folder you open the audio folder. this is the folder you install your music to. Just drag the mp3 format music from your source folder to the audio folder. wait till the copies are completed. then go to the bottom right of your screen down by the clock, and click on the little green arrow and Safely remove your device. click stop on the mass storage device..
Jan 16, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
URGENT!!!! MOTO RIZR Z3- MEMORY CARD n CAMERA LENS
no the phones will hold just up to the 2gb if you try using a larger card the phone will start operating slow or just will not read the card.
Oct 01, 2008 | Motorola Mobility RAZR V3
Motorola z3 themes
look under personalise setting and scroll down to skin. it should be there, Dont pay for stuff like this , its free on the net , look here for advise and tools .... http://www.planetmotox.net/
Dec 12, 2007 | Motorola Mobility RAZR V3
To install new skin
To install new skin ,u need to download skimanv0[1].47 software u find it on web.then download motorola USB driver software from motorola.com. u need to register on motorola.com. then skin manager software could read ur phone skin . Download skin from modmymoto.com and install it using skimanv0[1].47 on ur phone and enjoy!!!! i usind vista skin on my phone now, if any problem isteak007@gmail.com
Dec 11, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Dust under motorizr z3 screen
From
http://www.mobile-phones-uk.org.uk/motorola-rizr-z3.htm
Richard from UK
WARNING - DO NOT ATTEMPT THIS IF YOU ARE AT ALL UNSURE, AND DO NOT ATTEMPT THIS IF YOU DO NOT WISH TO RISK VOIDING YOUR WARRENTY!!!!! Turn off your phone, flip up the front panel and place the phone face down on a soft surface. Use a Torx T5 screwdriver/bit (available from some hardware/electronics stores or online) to carefully unscrew the small screws from the reverse of the front panel. Do not loose these!!! If you turn the phone over you should now be able to lift the top of the front cover away from the display, then slide down slightly to free it from the bottom of the display. Be very careful at this point as there is a small ribbon cable connecting the front cover buttons to the rest of the phone!!! This can be unplugged from the display board by carefully lifting it away, you may need to use a small screwdriver to gently lever it up but in my case this was not necessary. Now use a blower brush (available from any good camera shop) to blow away the dust from both the LCD display and the inside of the front cover. Then simply reassemble the phone by following the above instructions in reverse. Voila - dust free Z3!
Oct 30, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
56 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
