Question about Whirlpool RBS305PDS Electric Single Oven
RBS305PDS Broken Glass on Oven Door
After self cleaning, I opened the door and touched the glass with a damp sponge too soon - Glass is cracked and needs to be replaced. Do I get a WHOLE new door? Can I replace the glass myself (- and if so how do i order the part?) Or is this something I should get a professional to repair?
    President:
  • Whirlpool Master
  • 2,651 Answers
Inner door glass part number 4449259.. youll need to remoe the door from the unit and lay it on the table, thats the hardest part, theres a few different ways the door releases, so refer to your manual if available, then its just a matter of removing the screws form the door until you get to the broken panel, might thake a little time but as long as your patient no need to call service man. probly save $150
Posted on Nov 23, 2008
  • Help4mom Aug 19, 2011
    Same problem that I have but have problem putting it back. Would you have a step by step picture diagram how it is supposed to be.
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
I used the self cleaning feature on my stove and began to clean with a wet cloth before it was cool and the glass cracked on the door. is this able to be replaced?
yes the glass can be purchased separetly call your local part store give them the model number and they can get you the right part
Mar 14, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Is it safe to use the self cleaning if someone has used oven cleaners? is it safe to use self cleaning with a small crack in door glass?
No and no...
I would use the self cleaning anyway it gets everything too hot and cuases things to go wrong faster, like burning up the coatings on your wires and such...it is a bad idea but it sells ranges...so go figure.
Definetly noy if your glass has a crack... unless you want to replace it right now...
Heatman101
Jan 21, 2010 | KitchenAid KEBC101 Electric Single Oven
How to clean between doors of a wall oven a
2smart4u did not answer the question - how to clean between the glass on the oven door. I too have streaks inside the glass - looks bad - no way to clean it?
Dec 04, 2009 | Ovens
Dirty streaks between glass front
depends on type of unit,but most separate by opening oven door and removing the screws around the perimeter of the door, be careful reinstalling as to get inner and outer glass re-positioned right along with insulation,this is especially critical because the outer glass can't withstand self-clean temps and will break
Aug 22, 2009 | Ovens
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | GE JTP86 Electric Double Oven
Frigidaire Self Cleaning Electric Oven - Inner glass shattered, need part and instructions for door
It isn't that tough to change the glass assembly. Most of the Frigidaire have 4 screws that hold the front of the door to the inner part- sandwiching the glass in between. It is only sold as a unit- 2 glass pieces, assembled with an aluminum frame. Call All brands Appliance parts at 508-587-7100 and they'll get the part out to you. (Tell them Greasy Wheels sent ya, they'll take good care of you.) The most common reason the glass breaks, is a scratch in the glass. Sometimes it's just a dragged pan, other times it's from cleaning it with a sharp instrument. Don't do that....
Oct 24, 2017 | Ovens
you should be able to just replace the glass
Jan 12, 2009 | Ovens
Whirlpool RBS305PDS Electric Single Oven Logo
332 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
