Tv keeps flipping through set up menu
Can only turn the tv on and off by plugging it in. AND we it comes on, it just flips through the initial instruction set up menu and won't let you do anything else... HELP!!!!!
Magnavox TV
Model #19PRC2 3121
Serial # 44218170
Date Code: 1515A161G
Manufactured: March 1995
Chassis Model # 19E604-00AA
TV Rec Listed 347H
E10839
120 AMP 60Hz 120 Volt
TJBENGR
  • 121 Answers
SOURCE: Magnavox TV
If you use an antenna to get your signals...yes. If you have cable or satellite service....NO. None of your TV's have the new ATSC digital receivers, but cable or satellite don't need this.
Posted on Apr 22, 2008
jingjao
  • 252 Answers
SOURCE: philips/magnavox 20 in tv
check the horizontal output transistor or the vertical IC,maybe one of them is defected .
Posted on Oct 31, 2008
  • 88 Answers
SOURCE: OPERATING A MAGNAVOX TP3170 C101
i would try the magnavox website,just go to support or customer service and they should have a manual there.if not let me know how you make out.
Posted on Dec 07, 2008
  • 86 Answers
SOURCE: tv turned on then shuts off auto. in 15 sec.
One possible reason is the remote may have an "IR leak" where it is turning off the TV by emitting a signal of it's own.  To verify this, simply remove the batteries and turn the TV on.  If it stays on, that was the problem and you would need a new remote.  If this doesn't resolve this, try a power drain to rule out over-charged capacitors:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
Posted on Mar 25, 2009
  • 668 Answers
SOURCE: Menu Screen turns on/off on its own...alsoTv video flips through
The front panel Tactile Switches need to be replaced. Replace them all. This should be the part #. 23344507. You can order it through Encompass Elect. 800-638-3328.
Hope this helps,
Skyassoc
Posted on Jul 02, 2009
Set tv pcm output
is it flipping back to Auto setting without you turn off the tv or unplug it ?
http://www.tvrepair.localdomain.me/
Jan 07, 2014 | Toshiba Televison & Video
RCA TruFlat 27" TV Flips Through Channels by Itself
just the tacking switch to be replaced in order to function manualy..
Aug 10, 2008 | RCA Televison & Video
Tip
How to convert flip video to iPod,iPhone,Zune,Blackberry,PSP? Mac Flip Video...
Mac Flip Video Converter is made for converting flip video to iPod on mac and other portable devices.It is a versatile converter, and can easily transfer your flip video to other electrical devices, which is the exact need of most customers.
Flip Video Converter for Mac supports various input/output formats and almost all mainstream players. You can convert flip video to iPod and iPhone, convert flip video to zune,convert flip video to Blackberry,convert flip video to psp.
Step 1.Add Flip videos
Free download,install and run Flip Video Converter for mac.Click the 'Add File' button to add flip camcorder videos to Mac Flip Video Converter.
<img src="http://www.flip-converter.net/article-flip-mac/convert-flip-video-to-iPod-iPhone-Zune-Blackberry-PSP/add-flip-video.jpg">
Step 2.Set the "Profile
Click the 'Profile' drop-up list to select an output format for each flip video. Choose the portable device that you want to convert the flip video to.
Tips:Click 'Apply to all' if you want to convert all added videos to one format.
For example:
* Select the iPod type from the extended menu if you want to convert flip video to iPod.
* Select the iPhone type from the extended menu if you want to convert flip video to iPhone.
* More:Select the iMovie,iDVD,iTunes,...etc. from the drop-up list,you can find a series of other practical options to convert flip video to PSP,Apple TV,...etc. and most common video and audio formats.
Step 3.Start the conversion
Click the 'Start' button to start the conversion. When the conversion is done, click 'Open' and you will see all the converted files in the opened folder.
You can also edit your flip video and convert to other formats as you like,learn more about "How to edit your flip video".
on Sep 17, 2010 | Computers & Internet
I switch on my tv this morning but it dod not come on, instade green light came on with timer signal and keep flashing
Reset the TV to its factory setting, by entering in to its service menu option. Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 06, 2012 | Toshiba 36ZP48 36 inch TV
LC-37SH12U picture is upside down
Its somewhat common for this to happen and generally its an easy fix but since your set doesn't have the flip picture option your going to need to get into the service mode to fix this...below are the steps on how to get into the service menu on a Sharp TV...once your in there you need to look for either mirror image or H invert, and change that setting from on to off or off to on depending on what setting you have.
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu.
Nov 06, 2017 | Televison & Video
I want to attach a Vivitek 650HD projector to a ceiling mount, but am not sure if I mount it upside down. There doesn't seem to be a "flip" function to flip the picture.
I am 99% sure most projectors are mounted upside down. There should be a way to simply flip the image electronically via the option menu.
In most projector OCD menu (keep in mind you may want to do this before mounting), under the "Installation" or "Initial Installation" section should be an option about Projection mode/method. The options should allow you to pick front, rear, ceiling, or ceiling+rear. This sets the project to know when it will be in front of the screen, behind it, and/or attached to the ceiling (which it knows will be upside down). Then you simply set it to ceiling, mount the projector, and finish your other adjustments as needed.
Apr 27, 2011 | Televison & Video
Hope this helps,
Skyassoc
Jul 01, 2009 | Toshiba 32AF43 32" TV
Format keeps flipping over and over fast. Can't watch it at all.
there are format settings in your menu. highlight the highest format( 1080) or take it off auto format. this way it always in one format and will not switch even if the programming is in a lower format.
Jan 05, 2009 | Televison & Video
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
