Question about Sony Playstation 3 (PS3) Console
Pes 2009 (ps2) error loading
When I try to load the option file the blue bar thing gets 2/3rds of the way full then i get a message saying "error ocurrerd. loading failed. Retry or Cancel". If i press retry it happens again. If i press cancel and go through it is as if I have never ever started a PES 2009 option file before. If I go to where all my kits and points and various other edited things (a lot of them as well) should appear as I have done them, I get the originals. Obviously it is not recognising my option file, but if I cant fix this I have to go through nearly a months worth of internet history and 7 competitions including 3 long season leagues to get all back. I need a solid answer as if I have to start a new option file i will have to delete the other due to space issues. Please help ASAP.
Same problem here!! Zacitty, if you got a solution already! Please get back at me!! Just respond to this thread!! Thanx!!
Posted on Oct 28, 2009
I ve got sony ps2 in india and i always have to get a new gaming cd. is there any option to unlock my ps2 so that i even use pirated cds on it.
If your PS2 is made pre-2009 (has a manufacturer number less than 9xxxxxxxx) then you can use a bootloader to unlock the USB and hardrive to play "backed up" games and AVI movies.
You will need on of these things:
1) an original copy of 007 Agent Under Fire or an original PS1 game, to use as a "trigger" disk.
2) a original copy of Gameshark, SwapMagic, or CodeBreaker for PS2 (DL'ed copies wont work)
and you will need:
1) a memory card plugged into your PS2 slot 1
2) a USB drive
Now do this:
Load the boatloader ELF file from a burner "backup copy" of your 007 disk (using the "disk swap trick" on your "sensor-modded" PS2. I used ESR Disk Patcher and Apache V1.1 to alter the TOC values of the ELF file and "patch" the ISO file before burning, and I used the disk swap trick after playing level one of the game, saving, and then loading the "driving level" (level 2).
OR use SwapMagic or similar tool to load the bootloader. You can find Youtube videos detailing this process.
Install Free McBoot onto your memcard using the bootloader. You can use the "noobie package", use google to find this and put the files onto yor USB card. Voila! Now you can play AVI files or "backed up" games from USB or hard-drive, among other fun things.
Apr 24, 2011 | Sony PlayStation 2 (PS2) Console
Windows close and a blue page with white writing on comes up on screen, before you can read the fisrt line the computer starts in normal mode. it seems to work ok until the next time the same thing...
hi i have the solution to ur problem it's basically when ur windows file gets corrupted u will observe this sort of error message like what u have described a blue screen i recommend to install a fresh version of windows u can do this without losing any of ur critical data just follow these steps:
STEP 1:as soon as ur PC starts and u observe the logo on ur screen for e.x(INTEL,MERCURY) domething of this kind press F 8 immediately and u will see the next thing on ur screen is the PC asking to on ur system or load windows by providing some options select the option containing my msot recent settings that worked and ur windows will load surely without any blue screen error
STEP 2:as soon as ur windows will load try backing up ur critical data in a separate drive other than the drive containing ur windows files and folders and then install a fresh copy of windows or u can also repair ur previous windows using windows boot CD.
was this helpful to u if yes pls do rate my solution and thanks for visiting fixya.
NOTE: if the option u select do not work try other option specifying to load windows with all files and folders this will work sometimes but the above option works 99% perfect and if u face any problem just insert the windows boot CD and try repairing ur previous version of windows.
with warm regards-bonefirediv.
Apr 20, 2011 | Compaq Computers & Internet
Was working fine.... power whent out at house.... upon startup after that it would say windows is loading files..... then the windows bar with moving light along bottom then..... mouse on blank background...
Try booting it into safe mode by intercepting the boot up when the first screen comes up by hitting either F8 or F2, depending on your system. If you can't get in to windows this way, insert the cd that came with the computer, or a windows cd, and enter in to recovery mode. If you have the option to do a system restore, try that, you will not lose any file this way. If you can't do any of the above options, then a full system recovery is your only option. Do a google search for any errors or error messages that are popping up to specifically target what is happening with your system.
Feb 28, 2011 | Toshiba Satellite L305D-S5874 Laptop
Petz 5 not working. error message comes up
When you unintall Petz 5 you need to not save the petz, which is an option just before it starts uninstalling. Unistall, Then install it again, and run the game from My Computor, Petz, then play.
hope it works for you.
May 28, 2009 | Ubi Soft Catz 5 (Windows) (680901) for PC
My Toshiba L300 satellite pro wont load up
USE A BOOT CD AND RECOVER THE FILE AND MAKE SCAN VIRUS
rapidshare.com/files/51117041/ERD-2007.rar
IF YOU HAVE SATA DISK DISABILITATE SATA IN BIOS... TRY....
May 08, 2009 | Toshiba Satellite Pro L300 Notebook
Pes 2009 stopped loading
Delete The Update File From Game Data Utility And Redownload It Works Fine After. But Online Mode Does Not Work Anymore...
More And More Game Now Days Need All This Updatein Hardly Any Of It Works All I Ask For Is Workin Game's.. You Pay £39.99 For Wot Broken Games?
Nov 21, 2008 | Sony Playstation 3 (PS3) Console
I just bought a copy of Dogz5 with Catz5 attached
Dogz and Catz 5 both seem to have alot of problems! Disk space means you dont have enough room to copy it onto your computer, I would suggest deleting some downloaded things (nothing important though, you dont want to mess up your computer, lol)
Jan 21, 2008 | Ubi Soft Petz: Dogz 5 and Catz 5...
Option file problem on PES 2008
try cleaning your laser with a cotton bud dip in nail remover or any alcohol or any thing that evapourates quickly
Dec 04, 2007 | Sony PlayStation 2 (PS2) Console
Sony Playstation 3 (PS3) Console Logo
88 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
