Question about GE Profile DPSB620GCWW Gas Dryer
Can dryer be converted
We recently bought a 5 yr. old ge profile gas/electric dryer and it was hooked up as gas and we now have it hooked up as electric. however it will not heat up when it dries. is there something we need to do to change it from gas to electric?
    President:
  • GE Master
  • 2,651 Answers
Ummm, hter is NO way to convert a gas dryer to electric, you can have a gas dryer converted from naturall gas to lp gas, but not to electric, two totally different machines.
Posted on Nov 23, 2008
Dryer runs but no heat, recent power outage is there a correlation?
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | GE Profile Harmony DPGT750EC Electric...
Hi. My mother had a flood in her basement recently and although her 5 year old ge Profile gas dryer was set up on blocks off of the floor the bottom section got wet and it had stopped working. The...
you need to inspect the ignitor/glow coil that ignites the gas in the burner tube as they are very fragile,then on the burner tube body check the radint sensor eye it can be dirty,clean it first or then replace it,the gas valve boost and secondary coils on the gas valve could have been damaged and they keep the gas valve open to supply gas to the burner,then also check the thermal fuse on the vent blower housing as water could have ruined this component,also check all wire connections for water corrosion too
Jul 07, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile gas dryer tumbles but NO HEAT, not ignitor
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
New GE Profile dryer DPSE810EG7WT does not work. I wired exactly as old dryer. L1 L2 and neutral. The timer comes on but the machine does nothing! Thanks, Roger
if this is a gas dryer you would only need L1 OR L2.... NOT BOTH PHASES, this unit only needs the one leg of either A 120Volts or B 120Volts phase NOT BOTH PHASES 240 volts A.C. not 240 V.A.C. as in an electrically heated element will require to heat the system, NOW ...be careful now because one hot phase is connected where it shouldn't be!!!!
Apr 26, 2010 | GE DCVH515GF Gas Dryer
Convert propane hook up for dryer back to gas
the oriface size for propane and natural gas is the same it only has to be changed if you will be useing butane it should hook up and work the same but the propane will have a stronger sulfer smell than natural gas always connsult you gas provider if you are concerned they usualy will send tech to inspect if youhave questions for your safety
Nov 17, 2009 | GE Profile Harmony DPGT750EC Electric...
How do I light the ignite pilot light
Most new dryers don't actually have pilot lights. They use an electric heater that turns red hot, and ignites the gas at the right time. If your trying to light the pilot light (which probably doesn't exist) because the gas isnt being ignited,,, its possible that the electric igniter needs to be replaced.
Mar 13, 2009 | Kenmore Elite HE4 Electric Dryer
GE Gas dryer getting too hot
The gas burner valve is not the correct one for LP gas. You have to convert the valve as well as the orifices. The clicking is because it is over heating and cycling on and off o the high limit (safety thermostat)
Dec 18, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Duet Dryer (GEW9200LW) Control Panel doesn't work (all the time)
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE
Aug 25, 2008 | Whirlpool GEW9200L Electric Dryer
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile DPSB620GCWW Gas Dryer Logo
176 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
