Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
My new RHFE-1004FA has a slight whistle to it.
Went to camp today to start the furnace for the winter. When I fired it up it seems to have a slight whistle that is intermediate. It didn't do that this fall when I installed it. I did add a propane tank. Is it possible it has air in the line? If so how do I purge it?
  • bjd9 Nov 23, 2008
    Please help!
  • Mark Habeeb Dec 08, 2008
    I have the same problem with my 1004FA.Talked to tech. support they said it was from having high traces of methanol in the LP tanks.You have to use a manometer to adjust the air shutter on your Rinnai.
  • 1,420 Answers
May have a bad regulator on the tank or bad gas pressure. The colder it is, the less gas pressure you get out of the tank.
Posted on Jan 05, 2009
Stopped heating runs, but no heat... any parts available? Pretty sure is 120v ac.
Furnace Troubleshooting & Repairs ' HomeTips
Nov 25, 2015 - If your heater doesn't heat or works poorly, this furnace repair guide will help you troubleshoot and fix typical furnace problems with step-by-step advice. ... If your furnace's motor runs but the blower doesn't move air, the belt that ..... a tune upbut couldn't really find any thing wrong . last night and today when ...
Furnace Not Blowing Air? A Furnace Troubleshooting Guide
Dec 1, 2014 - A furnace works by a very simple principle, it uses some type of fuel ...This series of heated coils (called a heat exchanger) has a fan ... Today we will address the most common causes of a furnace not blowing air, and what you can do tofix it. ... It seems like this would be a no-brainer, but I can't tell you how ...
Simple Furnace Fixes ' The Family Handyman
Jan 01, 2016 | Heating & Cooling
Not enough heat coming from my Norseman furnace
I suspect the heat exchanger is caked with soot. The type of wood makes a very big difference in keeping them clean. The top cover is removable to access and clean it. No pallet or treated wood to keep it clean. Don't remove any screws you don't have to.
Dec 12, 2013 | Us Stove Company Vogelzang Norseman Add-On...
Rvp thermostat
After you replaced the batteries, you also need to sync the remote with the receiver for it to work again. Here's the manual link:
Nov 02, 2013 | Atwood Excalibur 8500 IV Furnace
Our coleman evcon furnace has started clicking over & over again before it starts up, we replaced the thermostat & the same thing happens.We are afraid that this is hard on the furnace & have resorted to...
Suspect that the igniter is causing the clicking (or could be a relay). Suggest having the furnace serviced. There is also a major recall for some models of the Coleman Evcon furnaces.
Oct 29, 2013 | Heating & Cooling
No spark on a 1995 polaris xlt 600
Could be a bad cdi box. Ive this problem with my xlt when I go for a ride, stop to eat and head back out to go home it won't start. I've usually had to choke it, and pull until it starts. My issue is carb settings. If you don't have spark I'd try replacing your cdi. If you know someone with the same sled try there's.
Dec 25, 2017 | Winter Sports
I had my 2002 buick lesabre tuned up last week. A couple times today, it wouldn't start the first time, but started okay. I added gas tonight and when I started, it wouldn't start and the second time, it...
ok, sounds like either a vacuum hose is unattached, that could be the whistling and/or the timing has been changed or is not correct.. it IS a timing issue but I think a loose vacuum hose can also affect that depending on where it is... look for a small maybe 3/8" diameter hose that is not attached to anything...
Mar 25, 2011 | 2002 Buick LeSabre
I need the sheet to correct the wistle noise on the 1004 e moore
The whistling noise may be from an improper air intake shutter control adjustment. For a Natural Gas Unit the air shutter control should only be open about 1/4 " . Also, when checking that, look to see if it's clogged with dust and lint. If so, vacuum it out using a crevice tool on the hose of your vacuum.
Vent-free Gas Appliances should be cleaned and serviced at least once a year. Usually in the Fall before firing it up for the heating season. Twice if you have house pets. Especially one's that shed a lot.
Jan 25, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a nat gas furnace that has 5 flashes on the board and will not light
Check for error code and check filters are not blocked and you have correct pressures. Make sure flue is not blocked
Dec 13, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
290 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
