Question about Ovens
GE Stove XL44 JGBP35WEV4WW
My oven/broiler does not work...I turn it on to bake and the temp does not go up from 100 degrees. I think the proglem is the igniter but I don't know where it is located. Please help.
Thank you.
Robin
hotuna
  • 288 Answers
SOURCE: Oven not working in Bake setting
Visually inspect the element for any kind of rupture on the shield covering the element. If it looks good the next step is the wire connections at the back of the element. Most likely is has a burnt wire.You will have to pull the back cover off to check this.
Posted on Nov 04, 2007
SOURCE: my ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Posted on Sep 08, 2008
  • 29 Answers
SOURCE: GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Posted on Jan 28, 2009
WRMtech
  • 70 Answers
SOURCE: ge xl44 oven not igniting but burners ignite
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit)
If you have an "open" circuit, the ignitor is bad
Posted on Feb 26, 2009
fixyourboard
  • 310 Answers
SOURCE: GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Posted on Aug 31, 2009
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
I have a GE Profile Spectra XL44. When I turned my oven on to 375 it read 100 degrees for 10 mins. I open the door and there was no heat. I then tried the broiler to make sure it worked and the the element...
i wouldn't say it is "normal", but yes, the bake element in the bottom could have burned out again. it depends too on how often you use the oven. if you use it every day, chances are it will burn out quicker than say someone who only uses it once a week. you can check the element for a burn hole or a blister break. you can also check it for continuity with an ohm meter if you have one. hope this helps.
Nov 07, 2009 | GE Ovens
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
Oven not working
hey, turn the oven on and see if you see an orange glow at the bottom. this would be your glow coil. exactly like the broil. if you do, take an amp probe and check the amp draw to it. it should be over 2.9 amps. if no glow or low amps replace and start baking. enjoy
May 17, 2009 | GE JGRP17 Gas Single Oven
Jan 28, 2009 | GE JGRP17 Gas Single Oven
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
