Question about Air Tools & Compressors
Ingersoll rand air compressor 185
My comp will not blow any air out and the intake is not sucking air. The rpms seems alot higher
  • 2 more comments
  • Anonymous Mar 12, 2014
    coalcer vessell heated up to the point where the plastic tubing in it's vicinity melted and burned. We suspect the wrong oil was used in the the coalescer
    Coalescer on a 185 ingersoll rand utility air trailer heated enough to melt plastic lines in its' vicinity
    need a manual for a 1999 ingersoll rand 185 xp utility air trailer
    AIR DISCHARGE TEMP SHUT DOWN
    Scholar:
  • 65 Answers
How old is the compressor ? This trouble shooting is directed to the vane and screw types of air compressors.
Caution,
For exact information on the equipment you are working on, go to the manufacturer’s maintenance and repair manual.
Here are some possibilities.
Compressor does not reach design pressure or capacity:
Air Pressure safety valve is leaking
Receiver air valve is open
Unloader valve is leaking
Loose Piping or fittings
Compressor will not load or unload:
Unloader valve defective
Air control valve is sticking or dirty
Unloader pressure is improperly set too high or too low
Water in the control lines
Plugged control lines
The air compressor CFPM is low:
Dirty air compressor air filter
Defective air intake control valve
High idle on power source improperly set
Damaged or worn rotor blades
Posted on Nov 25, 2008
I have an Ingersoll Rand UP6-7.5 air compressor. When you turn it on the fan for condenser runs but compressor wont start
Yes it is located in the intake air hose or air cleaner housing of the engine, It is called the "IAT" Intake Air temperature sensor"
Jan 13, 2017 | Ingersoll Rand Air Tools & Compressors
Where is oil cooler
Hi not totally familiar with this compressor but the oil cooler will be in front of the air intake vents with the cooling fan behind it
Mar 07, 2014 | Ingersoll Rand P185WJD Platinum Series Air...
I have two comp and they both are now dumping there oil throgh my air dryer.
With out a model # my suggestion would be to replace the separator on both units. Also make sure the scavenge line is not plugged. The separator removes oil from the compressed air and the scavenge line sucks the oil that is removed by the separator back to the air end. If either the scavenge line is plugged or the separator is fouled (dirty) the oil builds up and is carried over to the dryer and eventually Thur out the entire air system. If your equipment being used can not take any oil you need to take care of this problem asap.
May 17, 2011 | Ingersoll Rand Rotary Screw Compressor ...
Where can I get an oil fill drain plug for ingersoll rand compressor 2340L5-V?
There are alot of resources to obtain this. I would search the net or you can contact ingersoll. the 800 # on the unit would be a good place to start.
Jan 29, 2011 | Ingersoll Rand - Rand Type - 30...
My 185 ingersoll rand tow behind compressor shuts down when I open the valve to blow out sprinkler system...why
I worked at a tool rental store while attending college and noticed that IR compressors would shut down for a variety of safety reasons. Most common was low oil (engine), high temp (engine) and high air temp (compressor) and safety valve measuring access flow or free flow as if the hose becomes disconnected from tool (OSHA safety). Check all the safety control features of your unit for possible answer. Good luck
Oct 12, 2010 | Ingersoll Air Tools & Compressors
Need to know what compressor oil to use for 185 ingersoll rand compressor
The parts store,napa sells a air compressor oil that is compatible,It is called simply,air compressor oil.It is made just for compressors.
Oct 06, 2009 | Air Tools & Compressors
My rotary screw air compressor model SSREP100H
It's just too hot. Blow out the radiator weekly. There is an oil temp switch that might need replaced but the radiator is the most common problem with screw compressors. You can check the settings in the control panel, where you turn it on and off. It should be set for a high temp of 185°.
Aug 08, 2009 | Ingersoll Rand - Rand Type - 30...
1989 Ingersoll-Rand 185 cfm air compressor will not build up air
ITS A POSSIBILITY AND YOU BETTER HOPE ITS NOT SPINNING BECAUSE THE SCREW COMPRESSOR IS LOCKED UP. CHECK THE OIL LEVEL IN THE SUMP AND SEE IF THE ROTOR WILL TURN WHEN NOT RUNNING. TYPICALLY THE DIESEL ENGINE WILL TURN HIGHER RPMS WHEN IT HAS NO DRAG ( NO COMPRESSOR HOOKED UP ). YOU CAN GET THE PARTS FROM INGERSOL RAND OR ANY RENTAL YARD - UNITED, PENSKE, SUNBELT, ETC. THEIR MECHANIC SHOPS ARE USUALLY FOR HIRE AND CAN EVEN INSTALL IT FOR A CHARGE. ALSO MAKE SURE NOTHING BUILT A NEST IN THERE. IF YOU REMOVE THE SCREW, MAKE SURE AND WATCH FOR SHIMS. THOSE SHAFTS NEED TO LINED UP PERFECT TO REDUCE VIBRATION. GOOD LUCK
Apr 06, 2009 | Air Tools & Compressors
Ingersoll Rand M # 10T3NL Trouble
your problem seems to be that the non return valve is passing ,your local i/rand dealer can supply a new seal,there not expensive
Oct 08, 2008 | Ingersoll Rand - Rand Type - 30...
Air Tools & Compressors Logo
1,411 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
