Question about Dryers
Dryer makes screeching noise runs for awhile then shuts off.
When it first started it was intermittent and now it is constant and sounds like a fan belt screeching on an auto.
  • Anonymous Dec 05, 2008
    Same problem; noise is intermittent but seems to be getting worse. So far I'm guessing it's the dryer drum bearing, from what I've read elsewhere.
The 1,5 year new dryer makes a terrible screaching noise when it has a load of clothes in it. It still dries fine, no problem with the heating element. No noise without clothes, only when it has a load.
Posted on Nov 23, 2008
Question: Our Kenmore elite microwave model 66561689101 intermitting on and off. Most of the time it turns off just after it starts and then makes a weird screech sound and then starts back up and is good...
Only thing mechanical on nuker is the cooling fan assembly and /or the turntable platter. Something not turning properly is responsible for screeching noise. And if something is not turning properly there could be a sensor to detect this and shut unit down.
Nov 21, 2013 | Dryers
My holmes air purifier makes a screeching sound
If you can access the fan, spray lubricant onto the shaft as close to the fan body as possible. It will work it's way into the bearing
Apr 14, 2012 | Holmes Products Air Purifiers
I have a Whirlpool Duet Dryer about 4 years old. It just began making a screeching sound at startup. I say startup because it subsides after awhile. It sounds like a bad bearing , but acts like its a bad...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 06, 2011 | Whirlpool GEW9250 Electric Dryer
My dryer makes a loud screeching noise coming from the fan at the end of the motor, any ideas
the belt runs off the drum with a tensioner attached. It sounds like the bearing in the pulley is locked up causing the noise
Feb 04, 2010 | Dryers
Hello I have a Dell Dimension 3100 desktop. After
Bad Fan... either the CPU Fan or the Power Supply Fan or the Case Fan. If the PC is older than 4 years it is probably the Power Supply.
Dec 30, 2009 | Dell Dimension 3100 PC Desktop
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
TV goes off intermittently
sounds like an intermittent shut down which is heat related. some part , maybe one stuck on a heatsink is warming up and running too much current triggering shutdown.
to find it you can tell what is shutting down with a voltmeter, or you can heat suspected parts with a blow dryer to speed the shutdown .. or freeze spray to see if it goes beyond your shutdown time.
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Dryers Logo
396 people viewed this question
Top Dryers Experts
