Question about Dryers
Dryer will not start and it has power to it.
When I push the start button, the dryer will not start. I checked to see if it has power, which it does.
Maytag 6 cycle clothes dryer
model # LDE9306ACE
serial # 10632330QZ
  • 706 Answers
Hello jmhbfdtk4,
If your dryer has power and will not start when you press the start button, you may have an interlock that isn't made to allow it to start. It could be the door switch, a non-resettable fuse inside the dryer or something else. Are you getting any error messages on the system? Please advise and I will follow along with you...
Regards,
Rick
Posted on Nov 24, 2008
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Electric dryer will not start
Maybe a defective start button?
Nov 05, 2013 | LG DLE2516 Electric Dryer
My Dryer is a Maytag MGD5570, just under 4 years old. The dryer has power (light is on), but when I push the Start Button, nothing happens. I checked the Thermal Fuse with a continuity tester and it is not...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 03, 2011 | Maytag Dryers
LG Steam Dryer (DLEX3001R) won't start
Do you have 240 present at dryer. If so then check the belt and blower.
Oct 06, 2017 | LG Dryers
Dryer will not turn on when push button pushed
There should be an interlock device in the door that shuts the dryer off when the door is opened. The device is a switch that opens the power circuit. If the switch isn't being closed when the door closes, then the dryer won't start.
Apr 16, 2009 | Dryers
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Dryers Logo
137 people viewed this question
Top Dryers Experts
Marvin
Marvin
