Question about Xerox WorkCentre Pro 575 Plain Paper Laser Fax
Drum Life Warning Message
Have a 575 displaying this message after have installed a new drum. How do I clear this message?
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum. Yes No Press [1], then press [Enter]. The screen will display: Completed. Press [Stop] to return to the Standby Mode. These directions were found on the Xerox website, and worked for me.
Posted on Apr 19, 2007
How to fix brother printer drum error troubleshooting and routine maintenance
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one. The following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter as instructed below.
If you want to clear an error message related to the toner replacement, click here to see how to clear an error message after you replaced the toner cartridge.
"What is the difference between the toner cartridge and the drum unit?"
Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press Clear or Clear/Back on the control panel.?
    NOTE: The layout of a control panel differs depending on the model, but the Clear or Clear/Back button is located on the right side of the LCD screen as shown in illustration.
  4. Do one of the following.
    • If your Brother machine has a numeric keypad:
      Press 1 to reset the drum counter.
    • If your Brother machine doesn't have a numeric keypad:
      Press the Up Arrow Key to reset the drum counter.
  5. When the LCD shows Accepted, close the front cover.
Sep 11, 2017 | Brother Office Equipment & Supplies
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
What does a "K Drum Life" warning mean?
Meaning the life of the k drum is near and you need to replaced it soon or later
other message like below need attention
ecblank.gif C DRUM LIFE REMAINING nn% ecblank.gif M DRUM LIFE REMAINING nn% ecblank.gif Y DRUM LIFE REMAINING nn% ecblank.gif BELT LIFE REMAINING nn% ecblank.gif FUSER LIFE REMAINING nn% ecblank.gif K TONER REMAINING nn% ecblank.gif C TONER REMAINING nn% ecblank.gif M TONER REMAINING nn% ecblank.gif Y TONER REMAINING nn%
May 31, 2011 | OKI C3200n Led Printer
I have replaced the drum but still get a message that the drum life will end soon.
Open the front cover and press clear/back buttom
then press start
finally, press 00, then the screen will show accepted.
after that, you will be good to go.
Jan 26, 2011 | Brother MFC-7340 All-In-One Laser Printer
I have the MCF 7340. I am getting a message - End of Drum Soon. So, I bought a new drum ($120) and installed it. Now it says Drum end. and won't print. Ive turned the machine on and off several times,...
If you open the front cover of your printer where you install the toner cartridge and press the "Clear/Back" button with it open, an option comes up on your LCD Display that says "Replace Drum?" press 1 to reset it. That should fix your problem!
Sep 11, 2010 | Brother MFC-7340 All-In-One Laser Printer
Alarm says replace drum soon. Can the message be
The "replace drum soon" indicater is a warning for you to have a new replacement drum "on-hand". Soon the display will change to "REPLACE DRUM" AT WHICH TIME THE UNIT WILL STOP PRINTING.
When the new drum cartridge is then installed...the REPLACE DRUM indicator will be reset. DO NOT replace the drum before the machine says to.
Jun 04, 2010 | Muratec F320 Plain Paper LED Fax
In the display it says drum unit warning. What do...
Try removing the drum unit with the fax machine turned on.After reinstalling the drum check the display for a "new drum?" message.Answer "yes" and the mashine will reset the counter
May 16, 2010 | Office Equipment & Supplies
How do you reset memory board for muratec f-320 . I am trying to get rid of an error message"Replace drum unit printer not useable". Installed new drum unit and still gives the same error message.
Before doing complete Memory clear try the following...
Press..PROGRAM,*,*,I(thats the letter I),then ENTER.
That should reset it. Only replace the new drum into the machine when the machine says "Replace Drum"...NOT when it says "replace drum soon".
As a last resort a complete memory clear is PROGRAM,*,3.....but be warned this will clear all memory back to factory defaults "except" the Life Monitor which has the counters.
Oct 29, 2009 | Muratec F320 Plain Paper LED Fax
Toner life end warning light. replaced with new toner/drum still error
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered on open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press "+" key 10 times until the display reads 10.
5. Press "SET" key.
6. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
7. Close cover and see if Toner Life End error message has gone.
Jul 28, 2009 | Brother DCP-7020 Black and White Copier
Cannot reset the change drum soon message after replacing drum.
This message would appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
This message would continue to appear if the clear plastic starter sheet was removed from the "new" drum before it was installed. This plastic starter sheet, resets the drum counter. To reinstall drum with the starter sheet, please follow the instructions listed below:
Locate the starter sheet. Clear plastic sheet, 9 inches long, with a cut out in the center. The sheet will have "Initialization of your new drum successfully completed. Please discard this sheet" written on it.
If you cannot locate the starter sheet, contact the Brother Customer Service or the appropriate Brother authorized dealer.
additionl info HERE
Jul 11, 2008 | Brother MFC 4800 All-In-One Laser Printer
Xerox WorkCentre Pro 575 Plain Paper Laser Fax Logo
1,868 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
