Question about Sony Handycam DCR-HC42E Mini DV Digital Camcorder
LCD DISPLAY BLANK
I was recording a video whilst travelling in a bus with my LCD display opened when all of a sudden the screen started to change colour. At first it started getting dark , then after a few minutes it changed to red . I shut it OFF and after a few seconds I put it ON again . It was still red. I tried to increase the brightness but didnt succeed.I am not to sure if i have changed any settings while trying to increase the brightness. Slowly but surely it darkened and a few minutes later it blanked out. I shut it OFF and after a few seconds I put it ON again , it didnt com on. I read the manuel and i presumed that the problem could be due to condensation. I followed the solution by opening the cassette and after an hour or so I put it ON. I could see trough the View Finder and was able to record,however as soon as i opened the LCD Display every thing blanked off. Once I closed the LCD Display I was able to view through the View Finder. This problem has never occoured before. [ All remaining functions like play back , record etc. are proper.] Please let me know what is the problem. What should i do as for now. your prompt action will be highly appreciated. thanking you. Ryan Dsouza [INDIA]
  • Anonymous Dec 13, 2007
    I have Sony Handycam DCR-HC32 and I have been using it from last 1 and half years. All of a sudden one day my LCD display blanked out and I couldn't view anything. I shut it OFF and after a few seconds I put it ON again , it didnt com on. I read the manuel followed the solution by opening the cassette and after an hour or so I put it ON. I could see trough the View Finder and was able to record,however as soon as i opened the LCD Display every thing blanked off. Once I closed the LCD Display I was able to view through the View Finder. This problem has never occoured before. [ All remaining functions like play back , record etc. are proper.]
    It would be great if you can let me know the solution and procedure on how to get it resolved.
    Thanks in advance
    Chetan.
  • yossid Dec 13, 2007
    I have got the exact same fault sequence on my HC42 camera ( red and than nothing appears on the LCD. Can you guide me how to replace the flat cable ?
  • 89 Answers
The LCd connecting Flexible strip might be faulty. If you can view the picture in dark way,then the back light can be the faluty part. If they are all OK, then replace the LCD. The connecting strip is failing fast as per our experience and this costs US$ 21.00 and it is available with us.
Posted on Dec 30, 2006
SOURCE:
Why is canonS3IS screen blank
Please clarify your problem so someone can help you.
1. Does the camera power up? It has good batteries and the Status Indicator LED lights up showing that the camera has adequate battery power?
2. Is the screen blank when playing back previously taken photos also, just during recording, or all the time?
3. Can you see the camera menu's ok but not the live view of the subject.. or is everything blank?
4. Are you quite familiar with the menu's and most aspects of this camera model and you're sure all the settings are correct?
Please provide more detail.
In the meantime check the basics such as:
1. Press the display button on the back while the camera is on. This toggles the display setting between various settings such as Off/ On / Info. The screen may be switched off.
2, Check that the monitor brightness setting is set to medium at least in the menu's.
3. If the problem is only affecting recording then check that the main record settings are correct for the type of scene. For example don't use Beach, Snow, Candle or manual with a super high shutter speed while taking regular daylight shots.
2nd example .....If you set the shutter speed really high such as 1/1000 second while using indoor lighting the shots will be very dark.
4. If the LCD display has a hardware issue you could connect the camera to a TV using the video output jack and look at it that way. Then you'll know if the built-in LCD is ok or not.
5. Having a damaged or stuck video output jack WOULD cause this problem also,, since that circuitry is designed to automatically shut off the built-in LCD display when you connect a video cord to it. So leaving a cord plugged in to the video jack would shut off the display.
Jun 29, 2010 | Canon PowerShot S3 IS Digital Camera
Laptop computer connected to projector.
When the projector displays the background image and the lcd displays the desktop as normal you can drag the open windows to the left or right and display them on the projector. it sounds like this laptop has an internal video card. If you right click on the desktop it might give you options to configure the display settings for the video card. Not sure how you will get to it if it does not show up on the right click menu. Probably through the start menu or in the control panel there should be somewhere to change the settings for the video card. This will no be under the display settings though.
But once you find your dual display options you will be able to change it to make both displays the same
Jan 21, 2009 | Dell Latitude D600 Notebook
Blank Screen When Recording
hi, if you have an on screen display in camera mode you should check into the lens to see if your shutter or iris is opening.
Jul 23, 2008 | Panasonic NV-GS17 Mini DV Digital...
No display on view screen but able to record and play by connecting to TV
I have the same problem: Technical Service says flexible tape between LCD and camera could be open in some lines. The solution is to change that tape.
Jul 06, 2008 | Sony Handycam DCR-SR200 Camcorder
Blank Screen on my main display
You need to chance the strip in side the mobile. or else we need to change the display.
Feb 25, 2008 | Nokia 7390 Cellular Phone
No Display
ansh my cam also not display any thing but it will play the tape. i think your cam's problem is "Imager" give your cam to sony service center, they will repair your cam free only one time.
Jan 09, 2008 | Sony Handycam DCR-TRV265E Digital...
Blank LCD screen
no screen display
Dec 01, 2007 | Samsung Video Cameras
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Sony Handycam DCR-HC42E Mini DV Digital Camcorder Logo
158 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
