Question about Sport & Outdoor - Others
Overcharging my 2006 Polaris 450 Sportsman is overcharging when rpm's are in driving range over 3000rpm voltage goes to 18.5 vdc at idle voltage is normal at 14.3vdc
    New Friend:
  • 41 Answers
Sounds like the regulator/rectifier is bad
Posted on Nov 25, 2008
Will temperatures in the low 20 damage the Polaris sportsman 450
Hello, -
I tried to find information on the outdoors temperature range for a Polaris Sportsman 450, but did not find anything.
This is the number for Polaris Customer Service:
1 (888) 765-2747
Hours: Monday-Friday, 7 am - 7 pm, Central Time
They have a convoluted process for sending an email, but I suspect no one will be checking emails outside the Customer Service hours for phone answers. See this page:
To send an email, first you need to search the Help Center. I used the word "temperature" and clicked on Search. Then the form to fill out to send an email appeared.
Dec 22, 2017 | ATVs
Atv charging problems
115 ac volts at idle seems very high to me. if all 3 coils are putting out the same voltage I'd say its ok.
Jan 29, 2016 | Polaris ATV
Wont go in 2 wheel drive but switch works light come on dash ?
2004 Sportsman 700 AWD not working..... - Polaris ATV Forum > ... > ATV Repair and Maintenance
Feb 18, 2013 - Go Back · Polaris ATV Forum > Polaris ATV Technical Discussions > ATV ... AWD wont engage. 2. The instrument / speedo works. 3. The AWD switch is ...Polaris ATV Junkie! .... four wheel drive not working polaris sportsman. Won't go into 4 wheel drive
Feb 1, 2013
4 wheel drive not working
Nov 13, 2011
2004 700, 4WD engages by itself
Oct 28, 2011
4wd is stuck on
Dec 3, 2009
More results from www.polarisatvforums.c
Nov 29, 2015 | Polaris 2004 Sportsman 700 Twin
How do I replace a fuel filter on a 2006 Polaris Sportsman 450
The part you should have got would be #2520464 from polaris, this is a quick disconnect filter that is located not in the tank, but under the frame just behind and above the radiator. if you take your front box off you'll be able to get a good look at it. pretty easy to install. As for the tank, polaris doesn't offer service parts for thier pumps, which have a screen on them
Oct 18, 2014 | Polaris 2006 Sportsman 450
Engine won't idle /sometimes backfires
Check the MAF-MAP SENCER or it's a throttle position sencer is bad check both by replacing them and see if it works or the last result is idle control valve
Mar 24, 2014 | Polaris 2006 Sportsman 450
2004 sportsman 400 4x4 shifts late and hard going into high end
polaris drives are variable speed. they only have 2 ranges plus reverse. it sounds like either the driven clutch is slipping or the trans is slipping. the gear cogs inside may not be locking in properly and the shifter rods may need adjustment.
May 04, 2010 | Polaris ATV
2006 450 sportsman. Will start&idle. Increasing rpm will kill it sometimes.Is the slide in the carb vacuum activated because sometimes it will move sometimes it wont. Seems like not enough air and it...
Yes it is vacuum activated, I would check your vacuum lines for cracks and make sure they are snug. I would also check your air filter. If all looks good and it still happens I would clean youe carb because some dirt, rust or debris could have made its way there causing the inlet needle valve to be stuck open or it could be worn. Hope this helped
Mar 22, 2010 | Polaris ATV
Sport & Outdoor - Others Logo
273 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
