VCR cuts out when putting tape in & pushing play also has whine
We have a Aiwa HV-MX1u video cassette recorder that plays both NTSC and Pal and Mesecam. When we put the VHS tape into the slot and push play the video cassette whines for a second then the machine switches off.
  • pammcm411 Nov 23, 2008
5 Suggested Answers
nfandres
  • 168 Answers
SOURCE: aiwa mx100 (al system vcr)
if your vcr is a multisystem, select the proper system in your vcr for the video to be played. but if not, you cannot play your PAL in your NTSC vcr. good luck!
Posted on Feb 26, 2007
  • 275 Answers
SOURCE: Our Aiwa MX100 doesn't play our pal system tapes
Just Clean the Video heads with a Wet Type Head Cleaner. Do 2 or 3 runs. Should clear up the problem.
Benimur
  • 6966 Answers
SOURCE: Pal to NTSC
Hi, Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions. You are quite correct "Plays NTSC tapes to NTSC, Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom. Hope this be of some help to you. Good luck and kind regards.
Posted on Aug 24, 2007
  • 8457 Answers
SOURCE: I have an Aiwa hv-mx 100 vcr Now some time the
Pal and NTSC devices signal prequencies don't matches.Can't work to gether.U sure it different Pal and NTSC mix together devices before?
Posted on Oct 22, 2010
Will Aiwa HV-MX1 Playback Extended Play (EP) Speed?
Probably not then, but you could try a tape recorded at EP.
Jan 05, 2013 | Aiwa HV-MX1 VHS VCR
I no longer get a video signal out when I play a PAL tape when in the NTSC conversion mode. I do get the PAL signal out on my NTSC TV which I of course cannot view. Audio out works either way. What...
Hello
Please give me the brand names and model numbers of both devices you use with now. How are the confujured? I mean, the interconnection between them. Without any of these informating, it will be very difficult to assist you. Send me these. OK.
Oct 16, 2011 | Aiwa HV-MX1 VHS VCR
I have an Aiwa hv-mx 100 vcr Now some time the picure of my pal videos doesn't show in NTSC tv. Is it the problem of converter within vcr? or voltage regulater?
Oct 22, 2010 | Aiwa HV-MX100 VHS VCR
Converting NTSC home Video tapes to Pal DVD or NTSC DVD
You need either an NTSC DVD recorder (keep in mind that the US has 110 voltage, while Australia does not), or a computer card that supports NTSC. Some video capture cards support both NTSC and PAL (often switchable). Choose good quality, and pay attention to video/sound sync - some bad quality cards loose sync. Once the tapes are transferred to DVD - and keep it native NTSC all the way, they can be played on virtually any PAL DVD player/TV combo. With an NTSC source, it's best NOT to convert to PAL, while with a PAL source in the US, you'd need to convert to NTSC or only show the DVD on a computer (where NTSC/PAL doesn't matter).
Feb 19, 2009 | Panasonic DMR-ES35VS
Trouble recording and playing NTSC tapes on NTSC TV!!
Sounds like the video head is dirty. Take the top cover off VCR, locate the video head, which is the rotating shiny aluminum cylindrical piece. At the lower edge of this drum are the actual heads. Use a lint free cloth moistened with rubbing alcohol or product specifically designed for such cleaning, and carefully wipe the heads and drum. Just hold cloth over a finger, and rotate the drum. Sometimes you will need to do this a couple of times.
If VCR has alot of hours or an abrasive cleaning tape has been used excessively, the head could be worn out and a candidate for the trash, unless it is a high dollar unit.
Jun 11, 2008 | Aiwa HV-MX100 VHS VCR
Picture gets bad after playing a while
Just the usual problem of needing the rubber belts replaced.
They last about 6 years normally so you are overdue.
Buy a kit of belts for your model from all kinds of sites on the net and install them yourself if you are handy with delicate mechanisms.
Hope ya fix it!
Jan 14, 2008 | Aiwa HV-MX1 VHS VCR
Pal to NTSC
Aug 22, 2007 | Samsung SV5000W VHS VCR
VCR not working for some cassettes
What do you mean by "not able to play my VCR with some cassettes. " Is it that some tapes do not display images? No Video? From your name it seems that you are from India, Assuming that to be so, I also presume that you must be possesing a Multi-System VCR, to play back PAL Tapes from India, and NTSC tapes from the US. And if that is the case, I guess it is a simple problem of resetting the System standards. Please go to the Main menu of your VCR using the Remote, and select AUTO in System (You will be given choices of AUTO, PAL, NTSC 3.58, NTSC 4.43 and NTSC PB PAL. Likewise, it is entirely possible that your Television SYSTEm Standard has been accidentally changed. If it is Multi System TV, Then, again, using the Remote of the TV, select Menu, and then select AUTO in System. In all likelihood your problem should get solved.
May 13, 2007 | RCA VR605HF VHS VCR
Aiwa mx100 (al system vcr)
Feb 25, 2007 | Aiwa HV-MX100 VHS VCR
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
