Question about Dell E173FP 17" LCD Monitor
Is there an easy way to open this monitor?
I need to open up this dell 1704FPT monitor but can only get the sides to "pop" open. The four corners seem to be intent on not coming apart. If anyone can lend some advice that would be great. Thanks in advance!
  • kool2try May 11, 2010
    I followed the directions to open the monitor and I stripped it down to the board that needs to be removed to get to the power cord area. Am I going in the right direction and what is next, after I pull the board with the three screws? Will I need a meter of some sort to test? Thanks...
  • 624 Answers
-Flip the LCD face down and remove the screws that hold the base in place. -looking at the top edge of the LCD monitor you should see a small notch on each end between the front bezel and the back cover. -Using a plastic tool or a flat blade screw driver insert the tip and gently pop the case open. -Work your way around the edge of the case. -Once the LCD monitor is open unplug the control panel connector from the right side and remove the front bezel. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Mar 08, 2007
The notches are actually at the bottom edge of the monitor between the black back panel and the silver edge strip. Front panel and silver edge are a screwed together unit.
Posted on Mar 10, 2008
For the Dell 1704FPVt, remove the front bezel, you will see a small notch about 2 inches from each corner on the bottom. Be careful to unclip the small board that operates the power and adjustment buttons.
Tunr the unit over on the face andremove the 4 screws from the back center, then the 4 lugs, two from each side of the VGA and DVI ports.
The unit is now free from the back of the case.
Posted on Nov 01, 2011
    Scholar:
  • 53 Answers
The best tool to open is a butter knife it needs to slip in flat but the trick is to pry toward the thin edge lifting the back plastic away from the thin bazel but hold it tight cause the screen will be connected to the thin front part there are little plastic locks that hold these two part together after your done it just snaps back to gether
Posted on Jun 10, 2009
2 Suggested Answers
  • 624 Answers
SOURCE: Is there an easy way to open this monitor?
This is a duplicate post, click on the following link to go to the active posting: http://www.fixya.com/support/t128460-easy_way_open_monitor
Can I use the USB ports on the left side of my Dell 1704FPT monitor to connect devices? (e.g., Logitech webcam)
yes you can use the usb port but let me tell you one thing very clearly there is problem with these ports either they dont recognize your usb or maybe your monitor screen flickers... so use monitor port with a lot of care and i advised you to atlest read the manual before you do anything.
Jan 08, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704fpt usb ports: how do you find the
you should not need drivers for a usb port is the cable hooked up ? if so they are probably broken
Nov 27, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704FPT just went dead, will not turn on not even yellow light on power button - just seems to have died. Is there a way to reset? or is it time for a new one?
First you need to troubleshoot a little. You should first try another power cable for the monitor, if that doesn't help, you might be able to open up the monitor case and check wether the button is broken. If the button is broken, you're going to have to improvise a new one, since new buttons aren't really being sold. If that isn't the case, or if you can't open up the monitor, take it to computer shop, these things are easier to fix if you can look at it. I hope this helps, Yannick.
Jun 06, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
I have a Dell monitor model 1704FPT,, seems like the power button has come loose inside.. Can I get inside to repair it .. Thank you
You can turn counter-clockwise the screwz at the back cover of your monitor to open it & check if the power button is loose or defective, even notice if some internal part/s are cold soldered / defective. However, if it's still under Warranty, I recommend to bring the unit to an authorized service center for a Free service check-up & replacement part/s. best regards
May 22, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell UltraSharp 1704FPT 17 in
Remove the stand, look along the bottom edge - you will see two small slots, one either side. Poke something in the slots and wiggle slighly, the corner will come apart - then just pull until all the clips undo.
Sep 07, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704FPT Flat Screen Monitor USB ports
you need to run the usb to your computer first have you done that
May 08, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Pink tint on Dell 1704FPT Flatpanel LCD
The monitor is broken. The circuits that generate green in the RGB setup are not working. If its under warranty, replace it.
Apr 23, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704FPT Display Problem
It is your inverter/power supply board. Costs around $62.00 with shipping. Not a hard replacement if you have electronic maintenance experience.
Jan 22, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dec 28, 2006 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell E173FP 17" LCD Monitor Logo
1,225 people viewed this question
Alun Cox
