Question about Whirlpool SB160PEE Gas Single Oven
LED display says door. The control pannel wont work at all.
The led display on my whirlpool says door. The pad will not do anything. All the buttons will not work. I have unpluged the unit and pluged it back in and the "door" setting on LED is still on.
My problem has been repaired by my husband. I do not have the self cleaning on my oven yet the control board thought my self cleaning was on and the door was open. He had to jumper a wire between a connection on pannel to confuse the code and cause the board to set a new error code that could be reset. Which we were able to set the EO code and follow procedure for power disconnect and the board rest. We now have an opperatioal oven. Thank you .
Posted on Nov 24, 2008
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Tip
My Whirlpool oven wont work, and I get error code E1-F5 on display.
Hi.
On Whirlpool ranges the error code E1-F5 means that there is a problem with the door latch switch or with wiring to door latch.
Try first disconnecting power for five minutes, by either tripping circuit breaker or disconnecting power cord.
You may have to pressand hold the Cancel/Clear key on control pad down for about 1 minute to clear F5 failure code from ERC internal EPROM.
If that does not work, then there is a fault.
Disconnect power, access the door switch and testwires and connectors going from electronic control board to the doorswitch. An easy way to test wiring is by reading Ohms on the wire. Ifthe circuit is closed, the tester will read zero or low impedance, thatmeans that the wiring is good. If the multimeter set on impedance readsopen (no continuity), that means that the wire is broken and the wiringharness to the door latch must be replaced or fixed.
If there is no problem with the wires from Oven Electronic Control toDoor Latch Switch, then the door switch is probably faulty.
The switch can be tested reading Ohms on its contacts, and checking ifthe switch is opening and closing circuit while actuating the switchwith a pointed object at the same time.
If the switch is faulty, then replace the door switch.
After repairing the wiring or replacing the switch connect power back.You may have to pressand hold the Cancel/Clear key on control pad down for about 1 minuteagain, to clear F5 failure code from ERC internal EPROM. When F2 isshown on display, push the Cancel/Clear button again and observe theappliance working testing it again, to ensure that the repair had beensuccessful.
The tip is not only valid for Whirpool ovens, but also works on other brands that had been built by Whirlpool.
Best regards.
Ginko.
on Mar 22, 2010 | Ovens
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
KitchenAid Double Oven LED Blank
These ovens are made by Whirlpool. The electronic control board is notorious for going bad. If it is the one I am thinking about it is probably no longer available and will need to be rebuilt. I have had good success with Corecentrics Solutions. A google search will bring them up. I sent off the board and a rebuilt one arrived in about a week. Much cheaper than the original board too.
Nov 26, 2013 | KitchenAid Ovens
"Door Lock" LED flashing
that means you have door or lock problem may be the door latch failed after the oven self-cleaned,the heat might have blown a thermal overload fuse.first unplug the range and check the wires and connectors between the control and the door switch for damage. if they are okay , pull the range out and remove the back panel. check for the small gear motor that controls the latch and rotate it to unlock the door. . In the open back panel, look to your 10 o'clock position for a round part about the size of a quarter fastened with two screws. You can find out if this is your problem by unscrewing the fuse and taking the wires out, then joining the two wires together. Plug in the oven and see if the led disappears and the door lock works again. If it works, that fuse was your problem. if not then its the door hinge but be careful when doing this,to avoid more damage to the oven
Jan 09, 2010 | Whirlpool AKZ159IX Oven
Model RBD245PDB14 Error code F2 E6(left side) replaced original key pad with new. One week after install same error code and display blank out. Unpluged and reattached key pad cable but still diplays F2 E6...
If you replace the keypad and continue to have the same error you also have to replace the electronic control.
You can contact fixyourboard. com for a price to repair your control at a reduced price over a new control. It also comes back with a better warranty than anew control.
Jan 03, 2010 | Whirlpool Ovens
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
FO shows on led board for both ovens
HI. This is a basic communication issue that will concern, either the control board, or touch/Key pad assembly. Normally, this will produce a stuck key, which will cause one of the power relays to become suspended.
Determine if The problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting the key pad Ribbon Cable from control(main), and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
NOTE_ Some models incorporate the touch/Key pad into the EOC as a single assembly(Whole device), in which case this test is not necessary. Simply replace the EOC (Clock).
Nov 06, 2009 | GE Profile JT952 Electric Double Oven
My oven beeped and then the display went blank, light nworks when you open door and when push a button it beeps
The power is going out to the control panel. It is easy to replace the whole controller. Be careful of the key pad cable. it will break easily. The part is $225 for the controller and $172 for the key pad. There are 4 resisters that heat up and a zen diode that fails DZ1. U1 also may fail. My RBD306PDB10 works great now. Do pay attention to the cavity size after re-installing the board.
Mar 05, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool SB160PEE Gas Single Oven Logo
94 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
