Question about Kitchen Appliances - Others
Need a replacement dough paddle
K6722 where can I get a replacement, lost mine in a move........
  • hthohen Nov 24, 2008
    Toastmaster bread machine model 1172x
    I also need a replacement dough paddle.
    Thanks,
    Heather
    Champion:
  • 204 Answers
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Posted on Jan 11, 2009
I can hear the motor running, but the attachment does not move.
Sounds like what happened to my wife's mixer. There is one nylon gear in the drive assembly that is designed to break if too much load is put on the mixer. Like what can happen with dough or butter that is too hard/frozen. That is designed to save rest of the mixer. Sounds like you need to replace the KitchenAid Mixer Worm Drive and Pinion Gear Assembly. In our case, it was not the nylon gear that broke, but a small pin that is this gear assembly. By getting the assembly & not just the nylon gear, you cover more of your bases. I found a video on line that walks you through replacing the part. I also bought the part online. The assembly part, including shipping cost me $12.95.
Hope this helps.
Nov 30, 2011 | KitchenAid K5SS Heavy Duty Commercial...
I am looking for a paddle blade for my Magic Chef Bread Machine Mine was misplaced, and I am unable to locate a replacement. Model # CBM-310 part #(310187308676
Use your make + your model + your model number (omitting any dashes, slashes, or spaces) + the words KNEADING BLADE DOUGH PADDLE as your Internet search.
Example: For the Fredericks Home Bakery model KHB-178 enter your search as
FREDERICKS HOME BAKERY KHB178 KNEADING BLADE DOUGH PADDLE
Happy Hunting!
Note: Breadmakers model numbers are usually located on the backside or bottom of the unit, either on a printed decal or raised plastic embossment, and usually followed by abbreviations such as mdl, mdl no, model, model no, type, style, art, art no, article no, cat, cat no or catalog no.
Jun 21, 2011 | Magic Chef CBM310 Bread Maker
Crust is thick and hard, paddles tear large chunk from bottom of loaf when removed from pan.
unfortunately all bread machines leave the hole in the bottom where the paddle is. some machines leave a bigger hole than others, with the exception of the cuisinart cbk-200 which allows you to remove the dough, then remove the paddle, then reshape and replace the dough....One thing you can try to have a softer, lighter crust is to replace the water in your recipe with the same amount of milk. If the hole in the big hole in the loaf really bothers you I suppose you could remove the dough exactly at the end of the final knead, remove the paddle and replace the dough in the pan...I've never done it but I've certainly considered it! best wishes and happy breadmaking...
Nov 08, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Hi there! I've been using my toastmaster model 1142 bread maker a lot lately like almost every day and it has stopped mixing the dough. Once the dough is dense the motor sounds like its running but the...
Pull the pan out and turn the little paddle with your finger. Is the paddle slipping on the spindle? If yes, then your paddle is worn out. If you move the paddle around and it doesn't slip on the spindle then look to see if the ears on the bottom of the pan are turning too when you move the paddle. If yes, then your problem is further down in the machine. You may have a slipping belt. Those are some of the things you can check.
Nov 07, 2010 | Toastmaster 1142 Bread Maker
I need a dough blade for my welbilt bread machine model ABM-100-4
The original replacement paddle has been discontinued.
(Original) http://www.nelsonappliance.com/Welbilt+Bread+Maker+Dough+Paddles+%23BM-0550-04.html
The NEW substitude paddle they send you will work. It does not have the shorter flat piece your paddle has.
There are 2 used exact replacement paddles on ebay here:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250690885870&ih=015&category=20669&ssPageName=WDVW&rd=1
Thanks for choosig FixYa.
Kelly
Sep 15, 2010 | Welbilt Kitchen Appliances - Others
When you want to make only dough the dough senting does not work
The dough setting has a 20 minute delay before the paddles start to move. The manual say's "for most programs, there will be a 15-minute delay before mixing cycle begins"
Nov 07, 2009 | Black & Decker B2300 Bread Machine
Need kneading paddle
Not sure of your Model number but you can get replacement paddles for model 41080 and 41085 at https://www.amazon.com/Replacement-Kneading-West-Bend-Machines/dp/B001UM1HYA for $20.49
Oct 30, 2017 | West Bend 41089 Bread & Dough Maker
Need dough paddle for Regal Bread Machine K6725
Try http://breadmakerpartsemporium.ioffer.com/ They have manuals and parts for most breadmakers at very reasonable prices.
Dec 08, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
The paddle will not stay on the shaft while mixing dough.
Probably the paddle and shaft are worn. Both are replaceable. Buy a new Paddle and a Kneader mounting shaft unit (Part No. ADA 29A115)
Panasonic Parts
National Parts Center at 800-332-5368 between the hours of 9:00 a.m. and 8:00 p.m. EST Monday through Friday.
Nov 16, 2008 | Panasonic SD-YD250 Bread Maker
Kitchen Appliances - Others Logo
50 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
