Question about Whirlpool Calypso GVW9959K Top Load Washer
Can't find the pump
My husband thinks the pump is clogged - motor hums - washer will take water but then the motor hums. My husband has checked all the hoses. Is it hard to find the pump?
I had accidently dropped a box of tuna helper in B4 I did a load of clothes and didn't realize it. The cardboard box disinigrated completely. The sack of noodles and the sack of powder mix was intact.
    President:
  • Whirlpool Master
  • 2,651 Answers
The pump for this machine is located underneath the unit, lean the machine back, remove (3) 5/16 screws across the front bottom panel and remove the panle, the pump will be in the rear right side mounted upside down, wiht 2 hoses comin off the bak, the will be waterin the pump area( maybe as much as 2 gallonns so be prepared to get wet.
Posted on Nov 23, 2008
Have a Kenmore washer that will not agitate or spin water out. What is wrong with it?
does the motor hum? It is either a bad motor, clogged pump, or a bad timer
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jul 04, 2016 | Kenmore 22422 Top Load Washer
Motor hums but won't start
chances are the pump is blocked as well and unable to spin
Nov 03, 2013 | Dishwashers
My Electrolux washer will not drain water or fill water, it will spin. It is also making a humming noise
You need to check for the Humming noise as this can be the indicator to the problem, if this comes from the motor then the capacitor is faulty. Failure to switch on the INLET and the DRAIN pump can be related to fault in the control panel or this can also be due to faulty electric line voltage on the outlet.. So please check this out.
Also check the inlet and drain filters for clogging as a clogged drain pump can also hum.
Jan 12, 2013 | Washing Machines
My front loading GE washer WSSH300 will not drain.
Don't know if this will help or not, but your owners manual is available at http://genet.geappliances.com/DocSearch/Dispatcher
Water won’t drain
Drain hose is kinked or •
Straighten drain hose and make sure washer is not improperly connected sitting on it. Top of drain outlet should be less than 8 ft. (2.5 m)
above floor. Household drain may • Check household plumbing. You may need to call be clogged a plumber. Plumbing this washer directly to a pipe is hard on the motor. Usually the drain hose elbow is inserted in a stand pipe, meaning the washer would drain water on the floor is the stand pipe is clogged.
Several items can cause the lack of draining.
If you can get to the drain hose, try lowering to a point that it will drain into a bucket. If it drains the system is not clogged. If you advance the timer and the washer drains this maybe the culprit. The motor can overheat and shut off. I would advance the timer to spin and listen for a hum in the motor and then quiet, a sign that the motor has overheated. If the water drains it sounds like the timer is at fault.
I would first make sure the drain hose is properly installed and not kinked somewhere. In earlier GE's the water drain pump could clog, your manual doesn't indicate that as a defect. Regardless timer, motor and pump are in the cycle to empty the washer water.
Jul 10, 2010 | GE WSXH208A Front Load Washer
Frigidaire Affinity washer: Straining water pump? Humming.
more than likely the pump is clogged if you pull the the washer out away from the wall and then lean it back to get under it there is a hole to access the under side you can reach through to the pump then disconnect the large hose that goes from the tub to pump reach down inside of this hose remove the cup that has debris in it and clear it out remove the debris and reassemble the washer
Apr 03, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Water will npot comw out.humming noise
Sounds like a bad motor,but there are things you can check before replacing it.Check for an obstruction in the pump by taking off drain hose from the pump and look for clog. Or check to see if washer belt is burnt or slipping causing the motor to bind.
Feb 20, 2010 | Kenmore Washing Machines
Washer fills up but the will not wash
sounds like something is clogged in your pump under the washer.
see the motor drives the pump, but if it is clogged, the motor will not turn.
Sep 12, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not drain
90% chance that is the pump is pumping water at all, there is blockage between the tub and the drain pump. If there is no water coming out of the drain line. either extremely clogged(odd) or pump motor is bad, and windings are not allowing rotation.
May 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer fills with water then makes a humming
More likely the brushes on the drum motor. Check them first.
Feb 23, 2018 | Kenmore 24 in. 15953 Built-in Dishwasher
Stuck between cycles
It seams to me that your pump and/or water outlet is clogged. Humming noise comes from the water pump as it tries to pump out water. You should unplug the machine, unclog the outlet pipe if it is clogged. While you're at it check if the filter in front of the pump isn't clogged too.
Apr 10, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
123 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
