Question about Sanyo DRW-1000 DVD Recorder/VCR
Dvd will not read disc
My dvd is unable to read disc
    President:
  • 1,952 Answers
Upgrade the firmware on the product
Posted on Nov 23, 2008
  • mohammed marika thambi
    mohammed marika thambi Nov 23, 2008
    bad laser or needs to be cleaned
    try will use isobuster to force the dvd rom to read the cd or DVD to read. and it fine
  • 10,515 Answers
Try to use lense cleaner.........................
If that wld wrk, its perfect........................
You can replace the DVD drive with a new one. Liteon makes the original one. I replaced mine when it did the same thing. I used a Liteon 16X drive (overkill) to do so. It worked fine. Just do not update the firmware later for the drive. The original drive used a rubber belt for a drive and it stretches very quickly. You can also replace the belt on the drive but that is chancy. I would go for the drive replacement.
    Scholar:
  • 126 Answers
Hello schmidt755,
I am assuming this is a copied disc? Try it in a differnet DVD player, if it;s readable in another player the problem is the actual disc and not your player. DVD players are notorious for only reading certain disc types. If it's a dvd-rw it's most likely the player will NOT read it.
Hope this helps.
2 Suggested Answers
  • 4090 Answers
SOURCE: None of my dvd's will play. The dvd player reads
try cleaning the IRIS in the dvd player with a cleaning disk Quite often it is just dirt on the laser iris.
Posted on Sep 23, 2009
Insert disk all i get i load then it eject disk
Well it seems that your DVD player is having an issue reading the disc, I guess the first question is what kind of disc are you trying to insert? Is it a burned DVD or is it a movie dvd? This model is not a Blu Ray so if you are trying to use a Blu Ray disc then it will not read it. If you are trying to read a burned disc from someone then more then likely the disc was not finalized and is unable to recognize the disc, because the finalization process is where all the the information is written about what kind of disc it is and the format, codecs, etc. OR maybe the laser is dirty or the DVD player has kicked the bucket. Finally, the product DESC says it can read DVD-RAM, DVD-RW, DVD-R, DVD+RW, DVD+R, VHS formats, but I have found that some DVD units do not like certain brands of Blank DVDs. I hope this offers some ideas for you and good luck!
Oct 29, 2013 | Samsung DVD-VR357
Unable to read disc
question is that the only disc its not reading or you have tried other disc, if you tried other disc then you should return it for the lense to be changed if not check the disc properly and make sure it has no scratch, also you can try another CD/DVD disk format. the player might be selected for particular format
Jun 12, 2013 | Computers & Internet
Wii unable to read dvd
Try cleaning the lens with an approved laser lens cleaner.Check to see if you can hear the disc being spun. If not, the spindle motor is bad.If your discs are spinning but aren't being read, your laser could be damaged. Contact Nintendo for service, unless you're comfortable replacing the laser yourself. Buy one on line and get it replaced.
Thank you!
Jun 23, 2010 | Nintendo Wii Console
None of my dvd's will play. The dvd player reads no disc and the message on the tv reads unable to play disc.
Sep 23, 2009 | Televison & Video
UNABLE TO READ DISC
try some more different disc.also check out the disc in another player.if the disc are working in another player that means the disc are proper but the lens in the player is either got faulty or dust is got collected on the lens glass.get the lens cleaning cd from the local electronics computer shop and insert in the player and try inserting the cd if same error that means the lens is got faulty and needs replacement. thanks.
Jul 11, 2009 | GoVideo VR4940 DVD Player/VCR
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
R40 DVD Read Problem
Unable to read a CD-R or other recordable disc. DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Computer CD-ROM drive help and technical information. However, DVD-RAM discs cannot be read by standard DVD-ROM drives because of the differences in both reflectivity of the medium and the data format.
Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | IBM ThinkPad R40 2722 Notebook
Play station 2 won't read silver disc only reads blue disc
Hi Elvis,
The Blue back disc is CD format. The DVD laser circuit is giving you trouble. You can adjust the DVD pot some on the back of the Laser. Turn it about 3 degrees clockwise. Then put it the laser back in. Test the PS2 with no cover on, and use the white round disc from the laser drive cover to clamp a disc onto the spindle. Test DVD and PS2 Games that do not have Blue back.
Nov 28, 2007 | Sony PlayStation 2 (PS2) Console
Cannot read disc, unable to recognize..........HELP
In order to finalize your disc the dc210 MUST be plug into an outlet!!!
Oct 29, 2007 | Canon DC210 DVD Camcorder
Sanyo DRW-1000 DVD Recorder/VCR Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
