Question about Zanussi ZWF1430W Front Load Washer
240v 50Hz Zanussi zwf14581w wont start code EH1 with 220v 60Hz
We emigrated from UK to Mexico, taking our 2 favourite appliances, Boche diswasher and Zanussi washing machine, neither work here. We have dual voltage, 110v and 220v in the flat BUT i guess the frequency ,60Hz, is a problem for the motor so neither our diswasher nor our washing machine work. Is there anything we can do or have we made a very expensive mistake? The machines here in Mexico are several years behind the UK which is why we did it. If it meant spending a few hundred to resolve we would do it. Thanks in advance for any advice, be as technical as you like. The code above is to get this form to work we have zwf14581w not zwf1430w but i expect they are similar.
  • nightporter Nov 24, 2008
    Thank you, I'll contact them and ask.
  • 26 Answers
EH1 is a fault code that relates specifically to the frequency of the electrical supply. The power board is designed for 50Hz and will notice if it does n't get what its looking for.
You may be able to purchase a new main PCB that works with a 60Hz supply. You would need to contact Electrolux to ascertain whether this would be possible.
Posted on Nov 24, 2008
Can an appliance with a nema 6-20p plug be used in the uk?
It will probably require an adapter. If the equipment you're trying to power is dependent upon 60Hz power, it may not work correctly on the 50Hz power found in the UK... especially if it has an electric motor.
Aug 11, 2014 | Miele Rotary B890 Iron
E60 Error Code on converted 60Hz outlet
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Unplug your washer for 1 hour and then plug it back.See if this reset helps.
Aug 06, 2008 | AEG L74800 Front Load Washer
What is voltage of Ace touch dimmer
Hi Roger -
I just answered a related question of yours here. I see in this question that you are located in the UK. Household electrical devices in the US and Canada are 120V / 240V - 60Hz types. Larger appliances such as stoves, clothes dryers, electric heating and air conditioning equipment run on 240V - 60Hz. Small kitchen appliances like toaster, dishwashers, microwave ovens and common home appliances like radios, lamps, TVs, small space heaters, etc. all are 120V - 60Hz.
If the UK 230V devices operate on 50Hz (as I suspect they are), this can cause problems for many electronics, motor operated and devices that have transformers designed for 60Hz systems. Standard toggle switches wouldn't be a problem (provided you slect types rated greater than 230 V), but electronic types - like dimmers - could suffer from overheating issues.
Whatever you choose should be rated for the same (or greater) value of voltage, wattage or amperage and the identical frequency in hertz.
To your question: No, it is not likely that the Ace touch dimmer sold in the U.S. is rated for 240 volts - unless it is specifically identified for use at a voltage equal to or higher than what you want to use it on.
I hope this helps & good luck!
Jan 25, 2013 | Ace Hardware Ace Wire-In Touch Dimmer
I bought a LG Plasma TV RZ 42 PY 10X in in Italy where it is 220V 50Hz and now live in Mexico where it is 110V 60Hz. Although the TV Data states it's working range is 100 to 240V and 50 to 60Hz after a...
You need a power supply adapter. Might I suggest a 12v dc converter/inverter? The upside is that, for the money, you also get backup power to run your tv! Bonus!
You will need a good sized 12volt battery that will charge off of 110v house current and then the inverter will cover the rest. If the power there is bad or drops cycles you have everything covered because your inverter/tranformer does it all. Nice!
Here is the link to a website that sells these kinds of power supplies.
http://www.110220volts.com/Sub3/220inverters.html
Oct 11, 2010 | LG 42LC2D 42 in. LCD HDTV
Hi! I am interested in buying the Cuisinart Programmable Conical Burr Mill CBM18. I am thinking of buying it from a US and bringing it in to the UK and use together with a step-up mains transformer to...
Colinchee, this sounds like a rather complicated electrical engineering issue. Why not buy a coffee grinder in the UK design and rated for your power? It might even be cheaper and the guarantee will cover design flaws. Regards.
May 26, 2010 | Cuisinart Supreme Grind CCM-16PC Grinder
What power supply is needed for hp scanjet 2400
It is depends on your scanner power adapter and where u purchase the scanner from. Here if your scanner is from US then the adapter power input should be 100-120V 60Hz AC, if your scanner is from Euro, UK or Australia, the it should be 200-240V 50Hz AC, while if your scanner is from others place that not listed above then it should be 100-240V 50-60Hz AC.
But the best way is look at your adapter itself, u'll notice the power input and output from the adapter sticker.
If you lost your adapter then be sure to purchase 1 that can output a 12 VDC, 340mA, 4.22W adapter to the scanner.
YBC (/\)
Oct 20, 2009 | HP ScanJet 2400 Flatbed Scanner
Samsung LCD TV series 5 240Vac, 50Hz will it work with 60Hz?
no only the voltage is critical.the only point is you have to select right counrty and tv sound and picture system on setup menu!
Jun 11, 2009 | Samsung LT-P227W 22 in. HD-Ready LCD...
How to wire US dryer to UK supply - Whirlpool WED8300SWD
THIS document has a lot of info about the wiring for the unit you have. starting at page 6
I am, however confused about the voltage requirements as reference to 12/240VAC with a note to check the "rating" plate
If your unit is marked as 240VAC then it should be a simple task for an electrician to wire up the power. The instructions/details are in the manual (link provided) to connect it up as a standard 3 wire system used in the UK
The issue you have is that the motor may not like running on 50hz and may run HOT. It will also run slower on the lower frequency.
The specs on the website are as follows:-
Electrical Requirements
30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED
It may be worth getting all details off the rating plate and posting back here...
My suggestion is that you consult a qualified electrician before attempting to connect the unit to the power
Better safe than sorry.
Jul 08, 2008 | Dryers
Compatability with US 240v 60HZ 1phase wiring?
It should work OK The US system is 240V single phase (split) into two 120v branches. Aussi system is hot on both sides, with a center ground (a virtual ground system) Connect the 2 main wires (usually brown and blue) to the 240 (black and red), and connect the grounds (Green/yellow to green), and leave the neutral wire off.
Jun 14, 2008 | Saeco Royal Professional Espresso Machine
I'm in the UK bought my
This trimmer is only made to be used with 110V, we do not have this model in 240V. There is no way to stop the noise. If you would like to purchase a unit made for 240V please call 1-800-558-9441 and speak with one of the Andis customer service reps.
Thank you for purchasing Andis.
Dec 01, 2007 | Andis Outliner II Hair Trimmer
Zanussi ZWF1430W Front Load Washer Logo
1,205 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
