Question about Baumatic 18 in. BFD47 Free-standing Dishwasher
Baumatic bfd47ss error4
Error 4 draining then nothing.
I also tried the tipping 45 degrees to the front with my BKD46W and IT WORKED. Same problem - dishwasher made noise but did not fill with water. Thanks so much, probably saved me $150.
Posted on Jun 29, 2010
I read you have to remove cover and dry out "sump", I simply followed other advice of tipping it at 45degrees (get that mop ready) and hey presto. There may be a problem with a leaky component but so far so good.
Posted on Mar 27, 2010
  • joolsvern72 Jul 04, 2010
    I had the problem of it slowly BUT SURELY filling after the cycle had finished so after tipping (again) I turned the stopcock on the waterfeed it on and off with every cycle. After a couple of weeks I forgot and left it on but no more overfilling, I guess the valve may have stuck or something as there were no external signs of a problem.
My baumatic bk6el wont drain sin drain
Drain the machine , drain hose next to drank plug , undo the drain plug and make sure there is nothing stopping the propeller turns using a torch to see with , if all turns and nothing lodged there then it's your pump ps easy job to do and cheap to repair your self , if you need more information get back to me colin evans
Dec 13, 2017 | Baumatic Washing Machines
Baumatic BDW13 problems error 4
UNPLUG FIRST. Detach the hose or hoses. Take them put them in a bucket of bleach,and let it go through. Rinse and put back on. It should stop your problems,but it won't smell real nice.... Sorry! Get a fan and open the door if you don't live in a hot city!
Jun 12, 2014 | Dishwashers
Hi, I have error message 20 on BDW14 Baumatic. Dishwasher won't start. What does it mean? Thank you..
Error 20 is not a listed error in Baumatic dishwasher. They only mention E1 to E7.
There is a reset procedure for random errors which can be viewed at this page.
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3305-baumatic-bdw-dishwasher-fault-codes.html
Please check if this helps.
Apr 25, 2014 | Baumatic Dishwashers
Did anyone know where is the temperature sensor location in Baumatic BFD47SS
its usually threaded into the thermostat housing....
Sep 17, 2012 | Cars & Trucks
My Baumatic MEGA6SS washer is still full of water after the cycle is complete. Tried starting it on 'Drain' and nothing happens.
sounds like your drain pump is not working. that will be the case if there is no noise. if you hear something when it should be draining, check the screen to be sure it's not plugged.
Oct 11, 2009 | Baumatic MEGA6SS Front Load Washer
Baumatic BKD65SS
Shows ERR 4 on dispaly panel. what should i do?
Aug 30, 2008 | Baumatic 24 in. BFD60SS Free-standing...
BAUMATIC BFD47SS dishwasher won't start
Sounds like the water inlet solenoid valve is not opening. Not easy to get at to test, but if water is available at the hose inlet connection as you say there isn't anything else stopping water entering the wash cabinet.
Shouldn't be a lengthy repair - so I'd recommend getting a quote.
Aug 09, 2008 | Baumatic Dishwashers
Error4
check the manual see Error 4 trouble shot
Jun 20, 2008 | Haier hwr10xc6 Air Conditioner
Baumatic BHD 5
Is the water draining out of the machine? if not does it drain when you lower the pipe to the floor, if it does you need a new pump, if it doesn't you have a blockage.
Nov 26, 2007 | Baumatic 24 in. BFD60SS Free-standing...
Lights flashing and beeping on drain stage
When this has happened to us, it has meant a new control panel being fitted. It has been nothing to do with the draining process, just the electronics. The control panel isn't too expensive, but if you call a Baumatic engineer he will come out, do nothing and come out again and it will prob take about a month. I suggest you find a fixed price engineer who will perhaps be able to mend it on his first visit if you suggest the control panel. We have so many problems, we tend to buy in spares in advance so that they are in the house for the engineer and he can't fob us off with a return visit two weeks later. The parts that go are doorstraps, the control panel, the thermostat and the element. We haven't mended the control panel ourselves, but all other problems are pretty easy to do yourself.
Oct 07, 2007 | Baumatic 23 in. BDW5 Built-in Dishwasher
Baumatic 18 in. BFD47 Free-standing Dishwasher Logo
399 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
