Question about Creative Labs GigaWorks S700 Computer Speakers
Blown output amps on Creative GigaWorks 5.1 S700 sub-woofer
I would like to find a repair facility for this as Creative doesn't support this any longer. It is not under warranty. I blew the output amplifiers in the sub-woofer. I had the audio output of one computer, plugged into the input of an Audigy 4 line in on another computer, and forgot to turn down the volume on the Audigy 4 before turning on the other computer. I know it sounds unusual, but I had this like this for 3 1/2 years without a problem. It's bad enough that I'm an electronic technician myself, but I also knew what I could get away with. I would appreciate any help in this, even the schematics. I have also contacted Creative about the schematics, and am waiting to hear from anyone with help. Thanks, Bruce E. Krause Sr.
  • 99 Answers
SOURCE: Gigaworks S750 Sub - Pops and Cuts Out
There is obviously a problem on the amp board with 3 STA575 amplifiers. It may be that one of the diodes is shorted or one of the capacitors has dried up or shorted. For more information I have posted a link to a forum thread that contains all of the information you would need to fix the Gigaworks S750 system. If the information has not already been posted there then you can ask on there and the people there will point you in the right direction.
http://forums.creative.com/creativelabs/board/message?board.id=speakers&thread.id=8037&view=by_date_ascending&page=1
Posted on Jan 04, 2009
male_28_cam
  • 1555 Answers
SOURCE: Suddenly my speaker volume is low and scratchy
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
Posted on Aug 04, 2009
SOURCE: I have a Creative Gigaworks S700 (subwoofer) with
first fuse as standard is in the plug to the power adapter. The second fuse is located at the back of the box where the power lead goes into. It is covered so look closely you just need something flat to open it. I have the S750 and that is what im basing this on but if the s700 is the same then you will find this helpful. Sorry did not notice this before.
Hope this helps.
Posted on Mar 01, 2010
  • 159 Answers
SOURCE: i need to connect a
I wasn't sure if you were looking for the manual (connection instructions). If so, here's the manual:
http://ccftp.creative.com/manualdn/Manuals/TSD/7676/Creative%20GigaWorks%20S750%20Users%20Guide%20English.pdf
It's possible that your computer doesn't have the proper connections to connect these speakers. If that's the case you will need to upgrade your sound card.
I hope this helps and I which you the best of luck!!
Posted on Mar 01, 2011
SOURCE: Creative Gigaworks T20 (series I) Left
The problem that developed with my Creative Gigaworks and other is that occasionally it would not play at all. When the problem occurred, I could eventually get it to work again by turning it on and off several times. I opened up the powered unit (the Right speaker with the controls and found that the wires were really crammed in there, such that a white ribbon wire connector on the bottom was straining to the point of where it was slightly cracked. While playing audio through it, if I touched that wire ribbon, the sound would cut out. So I adjusted the wires slightly to relieve any tension force on that connector and it has not had the problem since. I would open up that unit and check for a similar poor or strained connection. To open the unit, carefully pull off the fabric speaker cover straight off, remove the 4 rubber inserts in the top 4 holes, and remove all 6 philips-head screws in those deeply recessed holes.
Posted on Dec 24, 2011
I have a Creative Gigaworks S700 i have checked both fuses still no power to control box
Stupid question: does the sound still work? it could be the LED just died after continual use (rare, since they last a long time, but not uncommon).
If not... it could be the controlling circuit board died. In which case, unless you have electronics repair experience, it would be probably more worthwhile to just replace the speakers, as pricey a model as it is.
Mar 23, 2012 | Creative Labs Gigaworks S750 Computer...
I need to connect a gigaworks s700 to my computer but i dont know how to.
Mar 01, 2011 | Creative Labs GigaWorks S700 Computer...
I have a Creative Gigaworks S700 (subwoofer) with no power out. LED off. Fuse ok.
Hope this helps.
Dec 11, 2009 | Creative Labs Gigaworks S750 Computer...
No power to main woofer and control box
are u willing to sell ur faulty sub wooder unit. please email me at zohaibasad@hotmail.com
Dec 07, 2009 | Creative Labs Gigaworks S750 Computer...
Left front speaker works the rest dont and the sub makes a hum
Either you have it configured incorrectly this time around, or the settings are defaulted back to original on your DVR........ adjust your DVR sound properties/settings. and check all wires/connections as well.
Apr 20, 2009 | Creative Labs Gigaworks S750 Computer...
Gigaworks
I could buy your sub if you want the power system in the sub is vary complex and it normaly fails on most peoples systems but i already had a custom amp and know want to use the woofer in my system email me if you interested
Sep 11, 2008 | Creative Labs Gigaworks S750 Computer...
Creative gigaworks s750 bass turning off
switch off the spk and check the woofer spk audio cable connection is it loose or something .swith it on and just connect only your woofer and see r u geeting any sound from it . bye
Sep 16, 2007 | Creative Labs Gigaworks S750 Computer...
Creative Labs GigaWorks S700 Computer Speakers Logo
141 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
