Question about Electronics - Others
Korg 05r/w not receiving midi
My korg 05r/w has stopped receiving midi. I have tried numerous things and resolutions but nothing works. I used loads of external synths and I am running cubase 4 on pc (win xp). I have tried it direct and via my amt8. if I put another device onto the same port, that other device works fine. As soon as the korg goes in, I put it in Global/Multi and nothing happens. Demos and alike plaback ok and the screen lights up, but no response from midi. Can you please help.
  • 219 Answers
Time to try a Factory Reset. If that does not work, your MIDI-driver chip inside is probably gone. Time for a Techie...
Posted on Jun 24, 2017
  • 1031 Answers
SOURCE: Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
Posted on May 25, 2008
SOURCE: Roland xp 50 storage medium problem
There is a solution that reads and writes on CF cards. It's call HDM uniflash or something like that.
I didn't try in my xp50, but others says it works.
A bit expensive for my taste, and maybe just for handy hands...
Posted on Jul 15, 2008
  • 392 Answers
SOURCE: trying to download user manual for korg x50
Get it from:
And take a look to:
Good luck
Posted on Mar 23, 2009
  • 45 Answers
SOURCE: I just loaded Cubase 4 onto my windows XP
what type of computer are oyu using
Posted on Feb 08, 2010
  • 4924 Answers
SOURCE: I recently bought a Korg
check the firewall in both places in control panel ..and on the antivirus if it has...and try to turn it off and see if it works ..cause if you have the correct driver and the software ..and it is seen already ..
check in device manager and see if ti is ok ..if it is in yellow it needs another driver cause it is not working ..look for the device by name ..
Posted on Jan 03, 2011
Unlocking disc for sounds
Probably your best bet is to use a sound editor/library. Move the sounds onto your computer, then into the librarian editor, then from there through midi into your keyboard.
Sep 16, 2017 | Korg Music
My korg N364 is out of tune. how do i fix it?
hello sir,
thanks from: SHAAD GONDEKAR
Feb 21, 2017 | Korg Music
I can`t load the OS in my KORG PA 80. No way to make it work. I think than the problem is the mother board.
Have you tried it with batteries? Are you sure the power supply is working correctly? It should not need the OS to operate as a keyboard disconnected from the computer.
The cable connection is just a MIDI cable that uses opto-isolators so the 2 items are electrically isolated from each other. The software driver for the Korg should load without problem. The Korg program itself may be looking for inputs that are not there when the keyboard is off and the program itself reaches a stop command.
If the PA80 will not work on just the power supply- the power supply can be the fault- it has an internal fuse. Finding a similar supply with the same coaxial plug wired the same polarity is the way to test it if the battery option is not available.
Mar 29, 2012 | Music
Korg ax3000 g display not working
It is likely something internal. The LCD is backlit so there is a chance it may be something on the order of a bad connection at the power supply input. Possibly a broken wire- as long as unit was not dropped, using a multi meter to check power is a pretty straight forward way to proceed.
If it got wet, there is possibly a burned out pico fuse, or corrosion on a connector or contact area for the rubber conductors for the display.
If unit was dropped- You may want to contact Korg to see if the display board is available. It likely is not. Which means it is a time and or money investment.
Feb 12, 2012 | Korg Music
My Korg CX-3 MIDI configuration tests for upgrading to Version 2 have failed numerous times. However, I am confident that it is not my MIDI interface. All Global settings and parameters seem to be...
If this is a flash upgrade to the unit be VERY careful as a failed upload can leave unit dead. They usually have pretty tight checks to prevent an error from killing the unit during the upload. For certain music products I have found that I had to upload an in between version first that was available before uploading the latest current version.
Jul 29, 2011 | Korg Cx3 61Key Modeled Combo Organ
Now frustration has set in as i am trying to get my Yamaha MU5 tone generator and Korg keyboard (Both midi) to link with my new Acer Aspire One D255 N550 netbook which i have loaded with an old version of...
I need to know how it's all hooked up first (IE Korg midi out to Yamaha in, Yamaha thru or out to Chord, USB from chord to Acer.....etc etc. etc.)
Also, see if the instruments can at least talk to each other.
Post a reply here.
Mar 14, 2011 | Acer (54.AA806.001) Sound Card
My korg x5 keyboard only turns on but nothing comes out of the display.nothing is loaded and no characters displayed.
Download the owners manual from here and try doing a reset to factory settings Manuals
Feb 18, 2011 | Korg X5d
Still dont get it
Hi Mark.
Siorry, but because of a fault with the system I am not able to reach you on the other thread.
Normalizing tracks means leveling volume settings for a group of tracks or samples to mix or combine them together without troubles like the ones you got.
to normalise tracks you can use the function built in on the Korg studio, see normalize in the software help.
When operating on MIDIs also remember that MIDIs are recorded on different channel (example drums, guitar bass guitar).eg:bTd Aerosmith MIDI archive
When you use them on a sequencer, and you operate on the volume, ensure
Mar 29, 2009 | Korg Legacy Collection
No sound
1. plug in some headphones into the jack.
2. connect to an amplifier or external source.
3. connect midi to a midi-compatible device and determine if device receives signal by pressing keys
If #1 or #2 passes, your speakers are bad.
If #1 & #2 fail, but #3 passes, your setting are set so that there is no sound, but the keybourd still recognizes input.
If all three fail, the keys do not send a signal at all, you should replace the keyboard.
Dec 19, 2008 | Korg Pa800 Synthesizer
Electronics - Others Logo
2,016 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
