Question about Metrologic Instruments OptimusSBT SP5535 Portable Terminal
Connect the OptimusSBT through bluetooth
Hello, i'm trying to set my SP5535 device. I am trying to connect the OptimusSBT through bluetooth, after loading the application of test through of the CardelIR. When attempt to load the application of the OptimusSBT, this does not manage to connect itself to the PC. Thanks for your help
0 characters
1 Points
Mc3100 find the wifi networks but can't enable the connection
I am working on the assumption that a laptop can correctly connect to the wireless network and only the MC3100 devices cannot connect.
FedEx and UPS had a similar issue as Windows CE wireless NIC's do not natively support higher level wireless encryption settings that modern wireless routers and Access Points can be configured with. This would result in an similar issue that you have described - the device can "see" the network as it is being broadcasted. When the authentication tries to occur, the two devices cannot "agree" and the device fails to connect.
If this is possible in your wireless environment, change the encryption settings on your wireless router or Access Point down from WPA2 or higher down to WEP remove encryption all together (for testing only).
It is very likely the MC3100 will be able to connect to a non-encrypted wireless network and a WEP enabled wireless network.
Once you get the device connected, try increasing the wireless encryption levels on the wireless network and see how high you can go and still have the MC3100 connect.
Hope this helps!
Nov 09, 2013 | Zebra Symbol MC3100 Wireless Mobile...
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it and what format browse select the file/folder where you want to save it (my pictures) most common
hope this helps
Aug 31, 2011 | Metrologic Instruments OptimusSBT SP5535...
How could i connect my nokia Bh 109 To my Pc Bluetooth
ok turn on your bluetooth in your cellphone network settings and search for devices or add another device. when your laptop appears on the search just connect it..
Jul 06, 2011 | Barcode Scanners
I have a bluetooth dongle. problem is i can only send files from my mobile phone (bluetooth enabled) to my pc and not vice versa. the bluetooth dongle (connected to my pc) can't search for other bluetooth...
You need to give more info, I'm afraid.
What type of phone do you have? What OS does it run? What kind of OS does your PC have? Did your adapter come with software? You say you can send files from your phone to your PC, but then you say that the PC doesn't the phone (?????!)
Since I don't have any clarification, here's some things you can try:
- Try shutting down and re-starting both your devices with the adapter still in. Try taking the adapater out, re-starting and then plugging the adapter in.
- Re-install or update the software for your adapter. If you decide to re-install, make sure you remove all th eold files completely. If it's plug and play, you can use device manager (assuming you have Windows) to find better software.
- Make sure your phone has the proper permissions set to receive files from your adapter. Since I do not know your phone model, try to google it.
- Try opening Bluetooth Devices in Control Panel. Click on Options and make sure you've enabled the PC to accept files from your mobile.
Bluetooth isn't two way automatic communication. Both devices that are using Bluetooth to communicate must individually have permissions set for the receiving of files from each device it connects to. You can send files all day long, but if the device youre sending to isnt set up to receive, it obviously won't work. Make sure you've enabled it in both the PC and the mobile.
Good luck.
Mar 21, 2011 | Barcode Scanners
Cant send files from my bluetooth device on my computer to my mobile
Do you have the application that runs the bluetooth application on your computer,because without that then you can't really share files with your phone and computer,first install the application on your pc and then get back just in case.
Dec 11, 2010 | Microsoft Barcode Scanners
Hello, I am with Motorola and have a MC5590. The scanner function does not appear to be working. I have version 6.5. Do you have an instruction set that can test the functionality of the scanner? Thank...
Hello Glenn,
to test the scanner I would suggest to download and install the Datawedge application. It is an desktop installation. As you will connect your MC55 to the Desktop per Active Sync the application will be installed also to your MC55.
The DataWedge aplication will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, if you scan a barcode a pop-up window will come up. Or if another application is running it will send the input to the application.
To download the DataWedge application please go to website and search for DataWedge, or use this direct link
Nov 08, 2010 | Zebra Symbol MC5590 Wireless Enterprise...
MS9535 BT Bluetooth Wireless Barcode Scanner mac
barcode scanner are just plug and play intallation... they just replaced your keyboard... but for your your assurance check or visit their site... have a look on this site
Nov 10, 2009 | Metrologic Instruments MS9535 VoyagerBT...
Deploying App (Post Deployment Error)
Under Windows CE 4.x series:
Look under here:
Motorola EMDK for .NET\v2.0\SDK\Smart Devices\wce400\armv4
for to copy to the PDA to install.
For Windows Mobile 5.x series:
Look under here:
Motorola EMDK for .NET\v2.0\SDK\Smart Devices\wce500\armv4i
Hopefully you won't get the error again. I personally just reference the dll under:
and have each symbol reference in my smart device deployment set to "local copy = true". Good day.
May 06, 2009 | Symbol MC9090 Barcode Scanner
Bluetooth says it''s not connected
You need to pair the device with the other peripherals or PC connection to make it work.
And where exactly are you trying to connect it? There could be compatibility issues here.
Jan 06, 2009 | Microvision Inc Microvision Flic Cordless...
Scan button do not function
open the OTL program.
go to 1 - Test Apps
go to 6 - Next Page
go to 1 - Auto Wedge On
do the tests now ;)
Nov 23, 2007 | Symbol MC1000 Barcode Scanner
Metrologic Instruments OptimusSBT SP5535 Portable Terminal Logo
Top Metrologic Instruments Barcode Scanners Experts
Brian Sullivan
Brian Sullivan
Are you a Metrologic Instruments Barcode Scanner Expert? Answer questions, earn points and help others
