Question about Toshiba Satellite A40 Notebook
Media Test Failure?
The hard drive on my Toshiba Satellite P25-S5092 fizzled out about a year ago, and I just installed a new hard drive, but when I turn the computer on, the same message comes up on the screen over and over again. It says :
MEDIA TEST FAILURE, CHECK CABLE
EXITING PXE-ROM
  • holiness1 Jan 27, 2009
    Immediately after bootup before POST test, i get the error message PXE-E61: Media Test Failure check cable and the next error message below it states PXE-MOF: Exiting PXE-ROM. These errors are the same before and after I've replaced the hard drive and RAM. It is on a Toshiba P25-S509
    Problem Solver:
  • 8 Answers
I f you have a recovery disk use that but back up your files and it should reset your toshiba to out of the box factory settings
Posted on Apr 04, 2010
Go in to the bios and change ur boot order so the harddrrive is before the network or lan
Posted on Dec 26, 2008
Toshiba satellite L455D-S5976 PXE-E61 media test failure...brand new hard drive What do I do???
You need to boot from an installation CD for the operating system, or the Toshiba restore set. New hard drives are completely blank when you purchase them. The computer is looking for something to boot from and cant find it, so it trys to boot from ethernet. Check your bios set up for boot order and boot devices. You might try disabling boot from network.
Hope this helps
May 04, 2012 | Toshiba Satellite L455D-S5976 Notebook
I recently installed windows seven and now it doesnt give me the option to connect to the internet via wifi,i also looked in device manager as it is not listed.
Hi, the problem here is that your pc was not designed for windows seven. You can try downloading the latest driver for your device, or you may need to use a plug in to usb, to get wifi. Also for windows 7 you will need a minimum of 2Gig of memory.
Aug 29, 2010 | Toshiba Satellite P25-S5092: P25-S5092...
Own a Toshiba P25-S5092. Will not power up. Goes
Power problems may do this, also if the CPU's heatsink has been loosen or detached, the CPU may me getting to hot and will self shutdown.
Aug 07, 2009 | Toshiba (K000006610) for Satellite P25...
Cannot get Toshiba P@% S507 to see new hard drive.
you can't use a restore disk made for a specific hard drive with a much larger hard drive. This information is checked by the restore cd. You would need to contact toshiba and get a regular windows install cd.
Apr 01, 2009 | Toshiba Satellite P25-S507 Notebook
My Toshiba Satellite P25 will no longer boot up but keeps running the following text. RTL8139(x)/8130/810X PCI ethernet controller v2.13 (020326) PXE-E61: Media Test Failure, check cable PXE M0F: exiting...
Hi and welcome to FixYa,
Initially, I am tempted to think that the CMOS/BIOS could not detect the internal hard disk and therefore is booting from the LAN. Pls reboot and enter CMOS/BIOS setup. Thereafter determine if the computer could detect the hard disk either auto or manually.
If the above solution has merit, pls click on my "Ask Me" to explore additional options, postback how things turned up or should you need additional information.
Good luck and Thank you for using FixYa.
Dec 03, 2008 | Toshiba Satellite P25-S507 Notebook
Bluetooth, Driver
All the toshiba products are her >< just select you model and then the driver you want
Oct 04, 2008 | Toshiba (K000006610) for Satellite P25...
Toshiba Satellite P25-S5092/ Computer will come on, but screen will not work. Wondering if it is most likely the LCD screen itself, the backlight or something else.
If you have deduced that indeed the Toshiba Satellite P25-S5092 will boot and therefore operational except no display on the screen, you can always verify by connecting an external monitor. You of course would need to press Fn + F? (the F key with the small monitor icon).
As to the LCD screen having no display, often this could either be the CCF lamps (cold cathode florescent) and/or the inverter that powers it. One way to verify this is by shining a flashlight obliquely to the screen and a portion of your desktop would show albeit very very dark. Often, it is the inverter that fails. In some instances it could even just be a cold solder, loose connection or capacitors that have dried up, leaky or blistering.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
May 18, 2008 | Toshiba Computers & Internet
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Toshiba Satellite A40 Notebook Logo
142 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
