Question about Maytag Dryers
Maytag LSE1000 Electric Washer/Dryer - error message 7E. Dryer won't operate.
KevinWhite
  • 1902 Answers
SOURCE: Maytag Electric Washer/Dryer - error
Hello
Error code 7E is a temperature control error and is caused due to overheating. Start with cleaning the vent and then please check the Thermal fuse located on the blower wheel housing inside the duct for continuity with an ohm meter. The fuse cannot be reset if it is bad then it needs replacement, if the fuse if fine then check the cycling thermostat. Please get back to me if you have any other questions.
Kevin
Posted on Nov 17, 2010
I need color coded wiring diagram for maytag combo model # lse8500ace
Double Check Model Number. Can't find anything with that model. Have LSE1000 and LSE7806 which are stacked Washer and Dryer
Nov 18, 2015 | Maytag Dryers
I have a maytag bravos quiet series 300 dryer with the error message f73. What does that mean?
Maytag Bravos 7.0 Cu. Ft. Electric Dryer F73 - Questions ...
www.fixya.com/search/p688923-maytag_bravos_7_0_cu_ft.../f73
have a bravo dryer , wont start shows error code f73 ? lights come on but dryer ... I think there was an F73 or F93 error message but we did not write it down.
Sep 22, 2015 | Maytag Dryers
I have a Maytag LSE1000. The dryer and washer each have an issue at the moment. The dryer intermittently won't engage when it is turned in. When you press the "regular" button to start it,...
I really have NO idea what's causing your Maytags to misbehave, BUT I can tell you that the Maytag service centers have always been very accommodating when I've called about problems with dishwashers, dryers, and washing machines.They have explained the construction of the appliance and even told me the type of tools I needed to make repairs! If you still have your owner's manual, the toll free number should be in there. I hope this helps!
Jul 28, 2011 | Maytag Dryers
I HAVE A MAYTAG LSE1000 WHICH WORKS WELL BUT NOT DRY CLOTHES
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 22, 2011 | Dryers
Maytag Electric Washer/Dryer - error message 7E. Dryer won't operate
Hello
Kevin
Nov 16, 2010 | Maytag Dryers
Maytag stack unit washer dryer error 7E washer works dryer wont do any thing
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 24, 2010 | Maytag Dryers
Dryer wont heat
First answer is yes; high resistance is good. I am not sure I understand the second question. The reasion one has to isolate the element is to avoid resistance from other parts. This, I believe , is the most likly problem.
Dec 26, 2008 | Maytag SDE2606 Electric Dryer
Does the Maytag LSE7806ACE require a 220 plug?
If you hook it up to 120 volts (by connecting L2[red] to common [white] the dryer will operate, but your heating element will only produce 25% of the heat it would on a 220v circuit. The drying time would be about 3 hours, and the auto dry setting may not work. Heat difference is about 5000 watts of heat on 220v, vs 1250 watts on 120v circuit.
Dec 19, 2007 | Maytag LSE7806A Top Load Stacked...
Maytag Neptune dryer error
To find out what the code means,
contact Maytag ServicesSM, Maytag Customer Assistance: U.S.A. 1-800-688-9900 or
Canada 1-800-688-2002.
Oct 06, 2007 | Maytag MDE2400AYW Neptune Electric Dryer
Dryers Logo
76 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
