Question about Saitek (PS28) Joystick, Throttle
Saitek X52 Joystick
When my Joystick is connected to the throttle control and then connected to my laptop via a USB port the throttle contorl works perfectly fine but the Joystick is not recognised and the lights blink. I have used my Joystick before, many times actually, this has happened once before and I managed to get it workign again, but only recently has this happened that I cannot get it. I use the Saitek X52 Flight Control for FSX. Please help me if you can. Thank you.
  • 1 more comment
  • mandatol Dec 20, 2008
    when i get to flight simulator x it seems that the joystick dont want to work
  • onelegvin Feb 08, 2009
    this is very annoying
  • onelegvin May 11, 2010
    how do get to the drivers??
I have had this exact problem and it's very frustrating! I finally fixed mine by doing the following:
I go under the hardware controller in windows and uninstall the drivers for the controller and uninstall any software associated like sst. Then I take ONLY the throttle controller and unplug the flight stick from it with the p/s2 connection. Then download the correct drivers for your stick model and run the install. It will ask for you to plug in the controller to continue and then you can plug in the isolated throttle controller through the usb. Install as usual and then when done you can plug in the flight stick to the throttle controller. Should work perfectly if done correctly.
Posted on Apr 28, 2012
    Problem Solver:
  • 11 Answers
Try deleting the drivers for the joystick, visit Saitek website get latest drivers and re-install the joystick, might fix the problem.
Posted on Nov 25, 2008
Sony vaio won't boot when saitek controllers are connected to its USB ports
the x52 drivers are problematic to begin with...
...but sounds like your computer is trying to boot on that device (as a primary/usb/H.D.) you either need to edit your boot options or reset the devices accordingly in your bios...
if your not familiar. . .DONT EVEN BOTHT...cuz you could wind up doing more harm than good ...tampering with your bios is tricky business (that even some of 'US' big boys have fried some processors, boards and even drives...!!! lol) so my honest advice to you if you're uncomfortable and unfamiliar with editing your system files (regedit/sysedit) &/or bios...ask a friend?! best of luck...
Apr 27, 2014 | Saitek Video Game Consoles & Games
I have a X52 pro. Throttle works fine, but the lights on the stick are constanly flashing and the stick doesn't work
if your X52 is less than 2 years old and you have the receipt, it's under warranty. Call Saitek and they will take it back and fix it (no charge). Mine is more than 2 years old so I am out of luck.
Jun 14, 2011 | Saitek X52 Flight Control System
My saitek x52 joystick wont work. Flashing lights every half second. Throttle works fine.
My X52 began doing this after hundreds of hours of use. Joystick lights flashing twice per second. Throttle operative but joystick (and buttons) not.
The problem was 2 wires inside the joystick base that had eventually been sawed in half by the sharp edge of the metal tube that carries the wires up into the stick. I have no doubt that this same issue could cause intermittent operation if just the insulation is worn off of more than one wire.
The fix: Remove the 4 screws from the base and lift the joystick assy out of the base. Inspect the wires where they emerge from the metal tube. You will find wires broken, or, insulation rubbed off. If you have broken wires, strip the ends and solder them together...you should have about 1/4 inch of "slop" up in the top end so you can pull the top wires down enough to strip and solder. If you re-insulate the solder splices with heat shrink or spaghetti tubing I would keep the amount used minimal...these wires need to remain somewhat flexible when the stick is being used.
Finally, I fixed the engineering defect that caused this in the first place by immobilizing the wire bundle with hot glue at the tube opening to prevent future contact with the sharp tube end. If your only problem was skinned insulation, this hot glue application may be all you need to do to keep the exposed conductors from contacting each other or the tube.
Speaking of "slop", you will also be contending with a bunch of silicone grease that lubricates the wire and mechanism.
Jun 12, 2011 | Saitek X52 Flight Control System
I'd like to use a Saitek X52 joystick/throttle system for Dark Void. Is there any way to do this?
Hello there Sir/Madam! My name is Alex and I work under FixYa.com expert team surveillance.
Unfortunately You can't do this, because Saitek X52 is not compatible with Dark Void serials, checked on main steam website.
Hope this helped and/or advised you on your next move.Please rate my solution, thanks in advance. Wish you good day
Adzic A.
May 09, 2011 | Capcom Dark Void for Windows
My joystick will not respond.
you have to plug the round tipped courd into the slot in both controllers, connecting both. you only plug one thing into your computer and that is the usb cord built into the throttle control.
Nov 16, 2009 | Saitek X52 Flight Control System
Lost the interconnecting cable, need help with replacement
It's a Male/Male PS/2 Cable. You have a couple of options:
1) Make it yourself. Find a couple of old PS/2 Mice, take em apart, tie em together and heat tube it OR
2) How can I get a Replacement Cable for my X52 Units?
Due to high demand, we cannot guarantee replacement cables for the X52 Pro. However, if you would like to request a cable please send your details to techsupport@saitek.com. We will process the request and inform you as to the availability of the cable.
May 03, 2009 | Saitek (PS28) Joystick, Throttle
Saitek X52 Flight Control Problem
Make sure you have the latest drivers for your operating system and graphics card, including direct X. Good luck
Feb 02, 2009 | Saitek X52 Flight Control System
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
X-axis trouble
I had the same problem with my X52 and searched high and low on the internet for a solution. What I did was pop the base off and found a loose connection on the x-axis wires. I re-routed both the x and y axis contact wires underneath the p/s2 port and put it back together. Seems to be working fine now. I will not that opening up the controller will void your warranty and it also could be possible that your x-axis problem could stem from something completely different from what was wrong with mine. You may contact me if you need any help with it. mynameisbob AT gmail DOT com.
Jul 19, 2008 | Saitek (PS28) Joystick, Throttle
X52 calibration
have the same problem with my X52; cant get the rudder control (twisting control) work fine, but it goes on its own way to the right and can't be calibrated no way. this is my 3rd SAITEK X52 (2 X52PRO, 1 X52), and all I can say is: SAITEK IS THE WORST **** I EVER HAD IN MY LIFE.
Mar 03, 2008 | Saitek (PS28) Joystick, Throttle
Saitek (PS28) Joystick, Throttle Logo
1,492 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Marvin
Marvin
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
