No Red in Picture through Component Cables
I purchased a Loewe Aconda 38'' ACO 9383 four years ago. After a couple of years, the picture suddenly didn't have any red in it through the component cables. It still had red in it if you hooked it up through Svideo. Unfortunately, that is not an HD picture. My set has been in a repair shop for the past two years!! The local repair shop has sent the chasis to the Loewe support (Loewe is no longer selling sets in the U.S.) service of Panurgy in NJ on several occasions. Panurgy says there is nothing wrong with the chasis and that they get a full hd picture when they hook it up in their shop. But, when the local repair shop hooks my tv up it has the same problem. Panurgy now says they will not invest anymore time to fixing my set because they can't find any problem with it. I am beyond frustrated! Does anyone know what the problem might be that this local repair shop might be overlooking. I can't say I have a lot of trust in their competency. Also, is there away to go around the issues with the component cables and use a hybrid VGA/HDMI cable to get an HD picture through the cable box? I have seen on-line a company called HD Fury that offers different types of connections. I'm not sure if the VGA connection is only meant for connecting to a computer monitor. Any help on this frustrating situation would be greatly appreciated!! Thanks.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, have you tried using another cable box or another component video source in case it is the cable box/source that is the problem?
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 30, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Scholar:
  • 126 Answers
Hello dlockett22,
The VGA cable is only meat for hookIng up a PC or laptop to your tv and will NOT give you HD. However, if you have a HDMI connector on your TV this should give you the red you are missing. HDMI will allow the audio and video to transfer in one cbale as apposed to the componet cables with 1 yello for video and a red and whit one for audio. The SVideo cable will give you pretty decent video, can you see a huge difference in viewing quality when you use the SVideo as opposed to the HD? Also, if you ae using the componet cbales that are red white and yellow to connect your cable box you are not really getting HD video. The svideo cable will give a higher quality picture more so than the componet cables.
Hope this helps.
Posted on Nov 23, 2008
    Sergeant:
  • 229 Answers
Your problem is cable related and I will tell you why I think this. As long as the remote repair shop is being honest they are not experiencing any problems and are getting HD signal at their shop.When you get it back it is doing it at home and at the repair shop. Invest in a set of high quality cables and have the signal strength of you cable input checked at home. I also had a problem with an older TV that was similiar to yours and when I routed it through an RF conveter it solved the issue. I suspect that the common denominator is connectivity with this set. VGA connections are usually for products like Netflix etc. but it is an HD connection nevertheless. You may want to see if your cable company will check signal strength and then get the cables. This should help.
Picture is distorted, enlarged, and bowed at the edges.
Pin-cushion distortion. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 14, 2015 | Loewe Aconda ACO9383 38" TV
Loewe Aconda ACO9383 PB1 w/ RCA Tube W97AJG14x08. Picture came on as usual, then picture reduced to 1/2 size, then screen went to black. Now front panel red and green light on....green blinks off then...
Hello Tom Helton,
Welcome, and thank you for using FixYa!
To answer your question: A television Professional will need to run through the gambit of tests on this television with a Volt-Meter and Osilliscope. Each resistor, transistor, capacitor, and soldier joint will have to be checked for failures.This is the only way to ensure if the television is salvageable. But it will cost at least $150 for diagnostics, then add on parts, and lastly, the repair labor cost. You could be looking at between $250.00 and $350.00 for the repair costs.I wish you the best with your decision between repair or replacement.
Have a great day!
Nov 17, 2011 | Loewe Aconda ACO9383 38" TV
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
My loewe acconda tv has horizontal red lines and
Any operation outside normal parameters would be considered "broken". Most broken TVs are repairable by a competent servicer for less than the price of a new one. A symptom like this however is the exception to the rule. It may very well be not cost-effective to repair. This is why most repair shops charge a bench fee for evaluation. If it is worth the peace of mind to know for sure then the investment of the minimum fee would be necessary.
Sep 05, 2009 | Loewe Aconda ACO9383 38" TV
Have Loewe Concept 84-100. Push power switch and set clicks on and off showing standby red indicator and then ready green indicator at about 2-3 second intervals, but nothing happens ie no picture no...
I've read on your site where a number of others have had this problem and on the strength of that have talked to a local technician who has more or less agreed - so will go with his expertise. Many thanks for your interest.
Jul 06, 2009 | Loewe Aconda ACO9383 38" TV
Loewe Aconda
$5000 over 5 years ago
Jul 15, 2008 | Loewe Aconda ACO9303 30" TV
Loewe Aconda 9383-S TV
flyback transformer...get a pro to fix it
Jan 27, 2008 | Loewe Aconda ACO9303 30" TV
Loewe Aconda 9383 TV
Possible loss of a secondary voltage check fuses, If fuses ok then require primary power supply kit. P No. 90415.900.
Jan 02, 2008 | Loewe Aconda ACO9303 30" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
