SOURCE: samsung side by side center divider front extremely hot
That sounds like you may have something in your condenser fan motor.. piece of bag, paper and may have stopped your fan altogther.. that would be the first place to check.. right by your compressor in the back of frig.
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
SOURCE: samsung model # rs2630sh side by side fridge. center strip is hot
I had the same problem, and it was the condenser fan motor. I ordered mine from www.partstore.com. It was half the price of sears.
I would suggest ordering the 2 "plastic bushings" for front and back of motor. I was able to reuse mine, but for a few dollars more it's worth it.
SOURCE: Samsung RS2630SH is hot
i doubt it is really hot but it needs to be warm it avoids condensation around the doors
SOURCE: My samsung rs2630sh is very very hot to the touch
The fan you should replace is called the condenser fan. It's the one that blows air across the outside coils. When it fails, you'll usually notice abnormal heating of the front of the divider between freezer and fridge.
