Question about Frigidaire FEF366 Electric Kitchen Range
Took the finish off on areas
Didn't take the time to wait until the hot surface light had gone off and proceeded to clean the areas which didn't come off easy with the cleaner. Being in a hurry I used my nail to try to get area cleaned. Have taken finish off in small areas. Is there anything I can do?
    President:
  • Frigidaire Master
  • 2,651 Answers
Find it hard to belive you would remove the finish with your fingernail, espacially if it was hot, thinkin youd melt your nail, but whatever, applying the cream to stubborn spots and then scraping them off with a razor blade, held flat not using hte point, is the best way to remove stains, and if the finish has been tremoved ther is nothin to to short of replacing the main top assembly
Posted on Nov 23, 2008
BLACK CARTRIDGE PRINTS IN SPASMS BUT COLOUR CARTRIDGE PRINTS FINE.
I didn't get your question,even I am trying to give you solution. Switch on the printer, left top cover wait until carriage arrive at middle, remove mono cartridge, take out swab nozzle area with good cotton or ear buds adding with alcohol(solvent) gently in one direction,repeat three to four times & shake well and see ink coming out from nozzle area?, clean nozzle area with tissue paper put it back & check for print..
Feb 04, 2012 | HP DeskJet 5150 InkJet Printer
When the full washing cycle has finished and all the lights are off, water starts running into the tub. Would keep filling forever if I didn't turn hot and cold off at the connection. I then push...
Water will not shut off
1. Defective timer ( timer fill the machine)---replace
2. Defective water level control---replace
3.foreign particles in mix & fill valve---clean out valve
4. Defective valve---replace
Sep 22, 2011 | Fisher and Paykel GWL11 Top Load Washer
Dometic rm2453. Works perfectly on gas or electric or dc. But, won't stay lit driving down the highway. Flame costantly blows out. Perfectly...
Interesting! Did you remove a shield that was there before? The only time I have had a problem like that is when we took the shield coving the pilot light area off and didn't put it back on right. You might want to check and make sure that everything is in place.
Aug 17, 2011 | Dometic RM2452 Refrigerator
A kind lady gave me a new Toastmaster bread machine 4 or 5 years ago, but my life was such that I thanked her, but said I didn't have time to devote to it. A year ago, I took it out and used it twice...
If you chose the "dough" program it won't get hot at all. If you chose the other programs and it never got hot then you do have a problem. Please advise which program you chose and we'll go from there.
Aug 12, 2011 | Toastmaster TBR2 Bread Maker
My samsung c5212 doesnt accept any other sim apart from my own sim numbers. ive forgotten phone lock code. pls help.
Follow these steps :
1- Save the important file and data on your mobile.
2- Type this code below on mobile screen :
*2767*3855# and wait until operation is finished.
After this operation ,the all lock codes in your mobile will be erased.
Jun 12, 2011 | Samsung C5212 Cell Phone
Error access to surface refused because the surface memory is gone
This should help
1 Uninstall the program DO NOT DELETE IT
2 Find the file in the all programs section of the start menu and select uninstall
3 Re-install, make sure it completly finishes
If that didn't work
Sorry for wasting your time
Thatnk you for your time good luck and I hope this helps
Jun 08, 2011 | Hasbro Small Soldiers Globotech Design Lab...
What type of transmission fluid and how much goes in a 1994 ford escort wagon? I just had it rebuilt and they didn't put much back in it. It barley reads on the stick.
When you read it, make sure the engine and trans are hot, the vehicle is in park, and you're on a level surface.
Ford uses Mercon ATF. Just add 1/4 of a quart at a time until it reads OK on the dipstick.
May 09, 2011 | 1994 Ford Escort
I have problem with games in samsung s3600i.When I play multiplayers game like PES 2009 and try to host or join game it shows "bluetooth is disabled" though it is enabled.I tried lots of time by...
TYPE THIS CODE :
*2767*3855#
THEN WAIT UNTIL IT FINISH RESET
THIS CODE RESET THE PHONE SETTINGS TO ITS ORIGINAL SETTINGS AND SOLVE ALL PROBLEMS
May 09, 2011 | Cell Phones
Vauxhall tigra 1996 1400.replaced rear brakes and bled them but the pedal is still soft when braking.
hi. im sure that brake pads are the right reference to your car, but did you cut the disc surface? if you didn´t you must wait until the brake pad surface be in complet contact with the disc surface, meanwile your pedal brake will be to soft because it makes kind of elastic movement in the brake pump. maybe that´s the problem, just wait a few more brakes and see what happens. hope this help you.
May 06, 2009 | Cars & Trucks
Frigidaire FEF366 Electric Kitchen Range Logo
215 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
