Question about ViewSonic VX910 19" LCD Monitor
Shadow strip down side of monitor
This just started this today when I booted up. It has happened before but don't remember the way to fix it , any ideas-thanks
  • 748 Answers
Is this Vista or XP with Google gadgets turned on? Turn these off and you'll get rid of the dark shadow.
Posted on Jan 05, 2009
My speakers won't turn on at the outlet that my power strip is plugged into, nor when plugged into any of the outlets on the strip, however the computer and monitor are running off the power strip and...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar:
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 01, 2011 | Logitech X-530 Computer Speakers
How can i fix the shadows on my acer monitor?
The fix is too easy to believe, but it works. I thas happened top me. I was told to separate the wires that come from the back of the monitor. If they are too close together or touching, you get "shadow" or "ghosting". Hope that helps. It fixed mine.
Sep 04, 2010 | Acer AL1715 17" LCD Monitor
Viewsonic VX2260wm has a shadow on the right side of the screen
install an AGP card in the AGP slot because internal display card of the motherboard does not support to high resolution because of insufficient memory . use 8X display card for the better result ..
Apr 18, 2010 | ViewSonic X Series VX2260wm 21.5"...
My monitor has a line down the middle with a shadow on one side of theline and I have osd locked on the screen and cannot get the program to show on screen to fix it
Vertical line down a monitor with a shadow genearlly is an indication of a video cable problem. Try removing the video cable from the computer and if it is still there and OSD is still locked it is an internal logic circuits problem
Dec 17, 2009 | LG Flatron L1515S 15" LCD Monitor
My monitor shows a shadow on the right side of icon, text, cursor, etc
I found that all I had was a bad connection of my plug from my monitor into the back of my machine.. jiggled the connection, tightened and all was fixed.
Oct 31, 2009 | Computers & Internet
Acer AL 1912 (black) resolution issue
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
May 27, 2009 | Acer AL1912 19" LCD Monitor
Shadows
Thank you.
Feb 07, 2009 | Acer X193W LCD Monitor
Monitor display is blurry, with shadows and waves next to text
Jnanda,
Could be one of two related situations both have to do with built up magnetic flux:
!. If you have used the monitor for a significant amount of time and have never degaussed it that might be it.
To fix: Go to where your monitor's controls are (eg screen size/position, Brightness, Contrast, etc.). Providing that we are referring to an older style monitor (like a TV) and not a flat screen, you should find a degaussing button located there. This button is marked with a depiction of a horseshoe magnet. Press it.
If you have on screen settings control, hit the menu button and select the icon that looks like a horseshoe magnet.
You'll hear a buzz and the screen will go kooky for a moment.
You're then degaussed. Your problem should go away.
2. You may have moved the monitor close to a source of electromagnetic interference (or vice-versa) this will also cause that sort of thing you describe (remember that there are electrical lines in the walls (another source of EMI)
In that case move the monitor away from the EMI source or move the EMI source away from the monitor.
Remember that it could be both 1 and 2. So if the problem lessens but does not go away fully try both steps.
Feb 06, 2009 | Dell E173FP 17" LCD Monitor
Samsung crt 591s blank problem
This eventually happens to all CRT monitors. Either the flyback transformer or some other critical componant has failed, and the screen cannot produce a picture. It might be an easy fix, but it would be better to get a new one.
Sep 09, 2008 | Computers & Internet
I-INC cy199
I have the exact same problem myself that just happened today. It apparently happens about a month or two after the warranty expires ;) I have 2 on my desk and one of them just stopped working. It is obviously a hardware problem and cannot be fixed without sending it back to the factory. They quote $65 for labor plus shipping. I might just go in the junk pile and I'll have to buy another.
Jul 23, 2008 | Hannstar I-Inc TW-191D Monitor
ViewSonic VX910 19" LCD Monitor Logo
171 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
