Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Bosch Nexxt series washer - water in softener dispenser
I have a front loading Bosch. There is always water in the fabric softener dispenser after the wash load is finished. This just started about a month ago. What is causing this and how can I fix the problem?
  • 3 more comments
  • smurga Nov 24, 2008
    I have removed the dispenser and have cleaned it as best I could. There is still water in the tray after a complete wash cycle. I was hoping for solution for this issue as the sympton must indicate a problem somewhere.
  • sjg70 Dec 15, 2008
    I have the same problem that after every wash even though i dont use a fabric softener the middle compartment on the dispenser is filled to the brim with water. it just doesnt seem right and i would like to fix this problem.
  • kwlrn09 Jan 29, 2009
    I have the same problem, water accumulates in the fabric softener dispenser. I have cleaned the dispenser and still have this issue. It didn't happen until 6+ months after I installed the washer. There must be a clog somewhere.
  • Anonymous Mar 26, 2009
    I have the exact same problem, fabric softener is always filled with water after a load. My washer is now 3 years old. It has always had a tiny little bit of water in fabric softener dispenser from the first day we bought it. Usually about one tablespoon. I have an extended warranty. The first time I called, they came and swapped out the dispense, said it was warped. 3 months later, and I am still seeing it fill completely up after every wash. This time it's 10 tablespoons. Yes, I counted. If anyone can provide assistance, I would greatly appreciate it.
  • Anonymous May 17, 2009
    I have the same problem with my fabric dispenser. Bosch replaced the dispenser, the smart board, told me the water was entering the machine at to much of a force, close the dispenser lid, you name it. Finally the solution was to replace the machine. I have had the new one 1 year and guess what....the 2nd machine is doing the same thing. My origional problem started in May of 06. Bosch has to know there is a problem
  • Bosch Master
  • 3,463 Answers
Hi. Remove dispenser, and thouroughly clean.
This should solve problem. If problem persists, don't worry about it tomuch, as long as it takes the conditioner down that is the main thing.
Posted on Nov 23, 2008
SOURCE:
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
Feb 24, 2014 | Bosch Washing Machines
Why is there water (up past the fill line) in the fabric softener dispenser when the wash cycle is complete? I have become accustomed to emptying it prior to each new load? i typically run the load on...
Bosch Nexxt 700 Series WFMC6401UC Front Load Washer
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Mar 30, 2010 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Sep 14, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Water left in fabric dispenser after load
The dispensers work by the siphon principle. You load the softener and at the proper time, the machine diverts water to the softener cup raising the level. In the softener cup, there is a tube loosely covered with a cap. When the level in the softener cup is raised high enough, a siphon effect is started and the softener is pulled from the cup into the washer. This will continue until the water quits flowing and air gets under tha cap, breaking the siphon. The amount of water remaining in the cup is dependent on the level of the cap, and the amount of residual water remaining in the dispenser fill tube once the siphon effect is broken. You can see this effect for yourself: take a measuring cup and slowly pour water into the softener cup, raising the level above the max line. When the level gets high enough, the contents of the cup will dispense. You can remove the cover cap that is a part of the dispenser and clean it; it will help. Removing the entire tray and cleaning all of the tubes and the cap assembly will also help. The only other thing that can be done is to change the dispensing supply valve, as it sounds like there may be some leak by after the fabric softener is dispensed. Having residual water isn't really hurting anything. It's only water, and the machine has dispensed the softener! Try the cleaning part first as this usually corrects the issue, and then the repair technician if it still bothers you. For as much as the extnded warranty costs, you should be completely satisfied with your machine.
Best regards, --W/D--
Sep 13, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Fabric Softener Dispenser wont drain
Try using a long handled babies bottle brush to clean out the rear of the dispenser and the tube leading down into the drum
Jun 18, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Water stays in rinse dispenser (fabric softener) when cycles are completed.
  • Hi,
Try these:
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
please rate my suggestion
May 21, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Some water backs up in the softener dispenser??
Service was here today and tilted the machine backward about 2-4 degrees. This solved the problem. Now fabric dispenser fully empties. Since the machine is 2.5 year old it is possible that over time it settled. I think though it is more likely the cold water dual inlet solenoid that is a bit constricted. If this fix does not last I will change it.
Feb 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosh washer won't dispense softener. cleaned the tray and tested it by filling with water and it drained completly out, so i know its not clogged. washed another load and softener still there at end of...
I had the same problem. the only thing that works for me is fulling the fabric softener compartment all the way to the top with water then it will syphon down! it adds it to the load at the start instead on the rinse cycle but its better then nothing!
Jul 28, 2008 | Bosch Washing Machines
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
1,729 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
