Sounds as if you have dirty drive path for the paper. Printers are bad about ink leaking (especially if not used often) and cleaning well involves some disassembly. The ink is very messy so wear rubber gloves. Clean around print cartridges, rollers, and also the glass for scans.
the most important is to remove all the air from the cartridge that has left inside durring refilling that is why professionals are using special machines that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill with out any special equipment
Good Day Sir, hope this will help you. print cartridge troubleshooting for hp officejet 4315 : 1. Remove the black print cartridge from the slot on the right. Do not touch the ink nozzles or the copper-colored contacts. check for possible damage to the copper-colored contacts or ink nozzles. 2. Reinsert the print cartridge by sliding it forward into the slot. Then push the print cartridge forward until it clicks into the socket. 3. Repeat steps 1 and 2 for the tri-color print cartridge on the left side. 4. If the problem persists, print a self-test report to determine if there is a problem with the print cartridges. 5. If the self test report shows a problem, clean the print cartridges. 6. If the problem persists, clean the copper-colored contacts of the print cartridges. 7. If you are still experiencing problems with printing, determine which print cartridge is experiencing the problem and replace it.
You can't set this up, it's done automatically by the printer depending on what you want printed.
Check the level of the black ink and print a text file directly from windows - don't use any HP soft.
check the ink level of the black cart. and try to clean the cart copper contacts with the lint free cloth.. n try to print.. else try it with a another set of new cart..
If there are a compatiable black cartridge
replace this cartridge with your old empty cartridge and print a test page (don't mind about printing of black )
If speed is correct,
then replace the black cartridge with another new cartridge.
(some time compatiable black cartridge not work properly to flow ink)
I have the 4315, so I am not sure if the answer is exactly the same. But there is a setting, for only printing in black ink and you need to disable it. Here is how to get to that setting: Go to "File" "Print" "Properties" "color" UNCLICK "Greyscale" and unclick "Black cartridge only."
