Dell 733 memory
I saw you offered some possitive online advice and thought maybe you could help me. I have the following Dell computer with only 256m of memory. I would like to inexpensively upgrade to at least 512m. How do find compatible memory boards? I went to ebay but am not totally comfortable with the items being offered.
Ed
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 3 Build 2600
OS Manufacturer Microsoft Corporation
System Name BONITA
System Manufacturer Dell Computer Corporation
System Model OptiPlex GX110
System Type X86-based PC
Processor x86 Family 6 Model 8 Stepping 6 Genuine Intel ~730 Mhz
BIOS Version/Date Dell Computer Corporation A06, 2/26/2001
SMBIOS Version 2.3
Windows Directory C:WINDOWS
System Directory C:WINDOWSsystem32
Boot Device DeviceHarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "5.1.2600.5512 (xpsp.080413-2111)"
User Name BONITAonita
Time Zone Central Standard Time
Total Physical Memory 256.00 MB
Available Physical Memory 32.77 MB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 529.58 MB
Page File C:pagefile.sys
    Master:
  • 409 Answers
Goto http://www.crucial.com/ and run their memory checker. it will tell you what can be put in your system. They are very competitively priced.
Posted on Nov 26, 2008
Which is the best website relating to carpet cleaning ann arbor?
There are lots of internet sites online which are offering advice concerning Carpet cleaners ann arbor . All these are particularly designed for men and women that are interested in quality advice concerning Carpet cleaners ann arbor . To learn more please see this web site:http://www.healthycarpetsnow.com/index.php/schedule-now/
Aug 17, 2017 | Saws
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
Vostro bios post beeps
Either your memory sticks are bad or, you have too much memory in the slots. Computers can accept a lot of memory but they can only recognize a certain amount. Make sure you don't have too much.
Jul 31, 2009 | Dell Vostro 420 Desktop Computer
Upgrading memory
hi If you go to www.crucial.com they will scan your pc & tell you what rams youhave & what you need. then buy from wherever. hope this helps blue51
Apr 14, 2009 | Dell Dimension 4600 PC Desktop
Ram upgrade problem
Are ou adding them along with the 256MB memory? That could be the problem
Mar 09, 2009 | Dell Dimension 2400 PC Desktop
2007 DELL XPS M140 LAPTOP WILL LOCK DUE TO 256M MEMORY STICK
Normally you boot up the laptop without a memory stick in the USB port.
Check your BIOS settings for the boot up device order.
You should have the hard drive as the first boot device, you can have the CD as the first boot device and the hard drive as the second boot device.
You should not have the USB port as the first boot device.
Feb 02, 2009 | Dell Inspiron XPS M140 Notebook
RAM Memory upgrade
K8V SE Deluxe DDR400 Memory Qualified Vender List
The following table lists the memory modules that have been tested
and qualified for use with this motherboard.
Size Module Vendor Model Chip Brand
SS/
DS
Chip
256M Micron MT8VDDT3264AG-40BC4 Micron SS MT46V32M8TG-5BC
512M Micron MT16VDDT6464AG-40BC4 Micron DS MT46V32M8TG-5BC
128M Infineon HYS64D16301GU-5-B Infineon SS HYB25D256160BT-5B
256M Infineon HYS64D32300GU-5-B Infineon SS HY25D256160BT-5B
512M Infineon HYS64D32300GU-5-B Infineon DS HY25D256800BT-5B
256M Infineon HYS64D3230HU-5-C Infineon SS HYB25D256800CE-5
512M Infineon HYS64D6320HU-5-C Infineon DS HYB25D256800CE-5
512M Samsung M368L6432ETM-CCC Samsung DS K4H560838E-TCCC
256M ATP AG32L64T8SQC4S Samsung SS K4H560838D-TCC4
256M Brain Power B6U808-256M-SAM-400 Samsung SS K4H560838D-TCC4
512M Brain Power B6U808-512M-SAM-400 Samsung DS K4H560838D-TCC4
512M Apacer 77.10736.464 Samsung DS K4H560838D-TCC4
256M ADATA MDOSS6F3G31YK1EZZ Samsung SS K4H560838D-TCC4
128M NANYA NT128D64SH4B1G-5T NANYA SS NT5DS16M16BT-5T
512M NANYA N512D64S8HB1G-5T NANYA DS NT5DS32M8BT-5T
256M Hynix HYMD232646B8J-D43 AA Hynix SS HY5DU56822BT-D43
256M Kingston KVR400X64C3A/256 Hynix SS HY5DV56822BT-D43
512M Kingston KVR400X64C3A/512 Hynix DS HY5DV56822BT-D43
512M Winbond W9451GCDB-5 Winbond DS W942508CH-5
256M Kingston KVR400X64C25/256 Winbond SS W942508BH-5
256M ADATA MDOWBFF3G31JB1EAE Winbond SS W942508BH-5
512M TwinMOS M2G9J16AGATT9F081AA4T TwinMOS DS TMD7608F8E50D
256M TwinMOS M2S9I08AFAPS9F0811A-T PSC SS A2S56D30ATP
256M KINGMAX MPXB62D-38KT3R KINGMAX SS KDL388P4EA-50
512M KINGMAX MPXC22D-38KT3R KINGMAX DS KDL388P4EA-50A
256M CORSAIR CMX256A-4000 XMS4000V1.1 CORSAIR SS
ive found the best prices at tigerdirect.com and they ship it right to your door. make sure the tiger ppl have the exact match and dont replace your order with more expensive replacements as some of these substitutions require voltages that your motherboard CAN NOT produce and will not work.. you also want to make sure to buy low density ram, it performs better, is a few bucks more than high density, but worth EVERY penny. E-bay is notorious for selling cheap high density ram on thier site.
If you stick to the list above, you shouldnt have any issues.
This should fixya up! please rate...
Oct 28, 2008 | Computers & Internet
Forgotten motherboard password of dell laptop model pp01l and system no. 7HYDT1-595B
Daustie, you don't read much, do you? What betenikomila is looking for an answer to is the BIOS/CMOS password, not the windows pass as you misguidedly offered bad advice to fixing.
What is needed is to do a procedure called "clearing NVRAM". The nvram is the non volatile memory that you computer keeps setting such as time, date, drives installed, and boot process. Think of it as the brains of the computer that tell it how to do the basic things.
The steps that follow are from Dell's website. PLEASE follow EXACTLY what it says, because you need to go inside the case & one small slip will cause your computer to become nothing more than a shiny doorstop. If you feel uncomfortable doing this, get someone that you trust to do it.
To clear NVRAM for all devices and restart the system, perform the following steps:
1. Turn off the computer and unplug it from the electrical outlet.
2. Remove the computer cover.
3. Move the jumper plug on the JPX2 jumper to pins 2 and 3 to erase all settings in System Setup at system start-up.
4. Replace the computer cover.
5. Attach the computer to the electrical outlet and turn it on.
6. After the system boots, turn it off, and unplug it from the electrical outlet.
7. Remove the computer cover.
8. Move the jumper plug on the JPX2 jumper back to pins 1 and 2.
9. Replace the computer cover.
10. Attach the computer to the electrical outlet and turn it on.
This comes from: Daustie, you don't read much, do you? What betenikomila is looking for an answer to is the BIOS/CMOS password, not the windows pass as you misguidedly offered bad advice to fixing.
This comes from:
http://support.dell.com/support/edocs/sy...
Sep 13, 2008 | Dell Latitude C640 Notebook
Memory and RAID Card for a Dell 1600SC
May be worth reseting the bios using the on-board jumper.
Jun 01, 2007 | Dell PowerEdge 1600SC Server
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
