Question about Goodman GMS90703BXA Heater
Furnace won't stay running
Just had goodman furnace installed. its 95%effiecient . i set the thermostat at a certain temprature when it reaches it the furnace shuts off like it suppose to . the temp drops furnaces won't kick back . the board is flashing 1 single flash. reset the furnace then does it again
  • 1 more comment
  • Anonymous Nov 24, 2008
    one flash furnace has to shut off to restart
  • Anonymous Feb 01, 2009
    I have same problem with a carrier furnace.
  • Anonymous Mar 17, 2014
    when the thermostat send a signal to the furnace. it start running and then i see the green light flashing the red light stay on. that indicate a pressure open fault.
  • 1,420 Answers
Furnace fails to operate.
• Integrated control module
diagnostic LED is
flashing ONE (1) flash.
• Furnace lockout due
to an excessive
number of ignition
“retries” (3 total)1.
• Failure to establish flame.
Cause may be no gas to
burners, front cover
pressure switch stuck open,
bad igniter or igniter
alignment, improper orifices,
or coated/oxidized or
improperly connected flame
• Loss of flame after establishment.
Cause may be
interrupted gas supply, lazy
burner flames (improper gas
pressure or restriction in flue
and/or combustion air
piping), front cover pressure
switch opening, or improper
induced draft blower
• Locate and correct gas
• Check front cover
pressure switch
operation (hose, wiring,
contact operation).
Correct if necessary.
• Replace or realign
• Check flame sense
signal. Sand sensor if
coated and/or oxidized.
• Check flue piping for
blockage, proper
length, elbows, and
• Verify proper induced
draft blower performance.
Posted on Nov 25, 2008
    New Friend:
  • 23 Answers
Check to make sure that it is draining right sounds like a draining problem if water gets in the inducer motor it will not vent the air right and the pressure switch won't close
Posted on Sep 18, 2013
Goodman Model GMV950905DX-an electrical surge burned out the transformer which I replaced, also replaced the circuit board. The variable speed furnace will no longer kick into high speed and it will l
If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
Dec 16, 2014 | Goodman Manufacturing Goodman Gas Furnace...
Furnace computer won't let furnace light
What is the model number? I have an SLP98 (installed on 11/29/2011).... and if I take the cover off the front of the furnace the panel that has the fancy "Lennox" badge on it) you will see two clear round windows about the size of a half dollar (one high on the furnace box and one lower on the blower box.) If you look downward into the window on the blower box you can see a red LED display that will sometimes flash error codes like E228 (one character at a time). If your model has something like this, let me know. I've done some DIY fixes recently out of necessity....and their easy.....and several technicians confessed they didn't know much, if anything, about the newer high effieciency Lennox gas furnaces.
Mar 01, 2013 | Lennox Heating & Cooling
Furnace blower runs after temp is reached
Is your tstat fan selector in auto?? Does the fan ever shut off?
Jul 18, 2017 | Heating & Cooling
The furnace comes on just briefly then goes off, after a time it will come back on and stay on. Is this normal?
Yes, depending on exactly what you mean by furnace on. Many furnace fans react only when plenum temprature reaches a certain amount.... (helps keep from blowing cold air) The circulation fan can run several times after burner shoutdown, based on the temp....
Mar 01, 2011 | Honeywell Heating & Cooling
I Have a beige goodman furnace (old ones) gmp... i replaced the circuit worked fine..then once it reached its desire temprature from thermostat.. fire goes out then 2 min following is the...
Check the pleum high limit switch. Jump this control out and see if the furance runs until the call for heat is satified. Do mot leave the high limit jumperd.
Jan 26, 2011 | Goodman CACF048B2A Air Conditioner
I have a downdraft Goodman furnace. On only some occasions the blower will start, then after a few seconds I will see the igniter light up, but then I do not get the rush of gas and lighting of the...
It sounds like you got a tough one there.When you say the blower starts up and then the igniter comes on are you refering to induced draft motor or main blower. The proper sequence is for the thermostat to call for heat at which point the induced draft motor should come on and run for 30-45 seconds,then the igniter should heat up for a few seconds then gas valve should open and main burner should light. After limit switch reaches set point for fan on ,blower should come on till after heat has reached thermostat setting then burner should go out, and blower run until fan off setting is reached on limit switch. If your furnace is not following this sequence and then not always doing the same thing in the same order,I would recommend that you change out board again. I have had several problems similar to this with Goodman units and all but one time installing new board solved it. That time I did everything I knew to do and talked to factory service techs repeatedly and finally installed new furnace. As far as your question about insulation,. As long as it is fire proof I can't see where it would hurt anything. Sorry I'm not more help. Good luck and thanks.
Nov 12, 2010 | Goodman GDS80904BNA Open Flame Heater
Furnace will not shut off after the setting is reached. have changed thermostat. Temperature reading goes down on thermostat, furnace still runs. Model : Goodman furnace,gmh95/gch9
Check if your thermostat is set on 'o fan' setting.
If it is, trey to set it on 'Auto-fan' instead.
since it seem as if the heating does go off,only the fan may be running continuously.
this is possible if the thermostat is incorrectly set or installed.
good luck.
Jan 30, 2010 | Goodman GMS90703BXA Heater
Electric furnace won't shut off
It sounds like a bad or badly miswired T-stat
Jan 20, 2009 | Goodman CLQ36AR49 Air Conditioner
Electric furnace runs but won't shut off on heat setting
I would insist that Sears either have a Senior tech come out and fix it or return it to the state it was prior to them touching. Then call some one else. Have them involve the Goodman rep in your area.
Goodman GMS90904CXA Wont ignite, light blinks 3 times
I had the same problem, I had to remove the lower black rubber stopper right next to the exaust fan and hook up a drain to the unit, as soon as the water drained out the furnace fired right up.
Nov 19, 2008 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
1,903 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
