Question about Whirlpool LER5636P Electric Dryer
HOW DO I GET TO THE FRONT OF MY MAYTAG ELECTRIC DRYER TO FIX A PU
THE PULLEY IN THE BOTTOM FRONT OF MY MAYTAG DRYER SQUEAKS. HOW DO I GET THE DRYER APART TO GET INTO THE FRONT OF IT? ITS MODEL NO. LDE7334ACE
  • meadow9625-f Jan 19, 2009
    I have a Maytag electric dryer model # LDE7334ACE that squeaks while running through the dry cycles. It began as some squeaking at the beginning of the cycle and then it would stop. Has recently progressed to squeaking off and on throughout the cycle. Can you please provide suggestions as to what part(s) may be causing this? Thank you.
    Genius:
  • 1,198 Answers
A lot of appliances have a spring latch under the front of the top. You need a putty knife to push this in to release the top, one on each front corner. The top will hinge up. Then a screw will be holding the front on, one on each corner of the top area. Some fronts have screws down on the lower front, you really have to look for them. Make sure the power is off!
Posted on Nov 25, 2008
Dryer making a loud squeaking noise
Hi, You probably will need the following parts to fix the squeal;
6-3705180 Idler arm $6.78
6-3700340 bearing $16.04
[2] 6-3129480 Drum roller shaft $5.53
[2] 12001541 rollers $22.04
33002535 belt $23.80
MAKE SURE DRYER IS UNPLUGGED BEFORE WORKING ON IT
Remove two screws at front bottom, pull front out toward you and remove wires from door switch and remove. Remove front bulkhead and drum. Check all of these parts I listed and replace as needed. Hope this helps
Jan 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag model MDE308DAYW squeaks and grinds when turned on.
i would assume that either the rear roller(located directly atop your heater, or yout idler pulley has gone bad , parts are probly about $40.. not a bad repair, you can probly find a how to on you tube
Oct 09, 2010 | Maytag MDE308DAYW Electric Dryer
My dryer has a high pitched squeak. What could it be? It is not loose coins or other foreign objects. It appears the little white pulley is not turning when the dryer is on. What can I do to fix this?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer Squeaks when operating. Dries fine; but just squeaks, it comes and goes. Bearings/etc. seem to be ok.
check the tension pulley at the belt. If it has an inspection plate
in the back you can oil the pulley, otherwise you have to dis-assemble to get to the pulley
Jul 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My dryer squeaks model #mde3600ayw
Many reasons for this to happen. First the seal surrounding the drum to the front panel maybe dirty causing this squeak
In the other hand most squeaks are caused by the dried up bearing inside the roller for the belt tensioner. If so replace the belt and tensioner pulley for the belt gets stretched by a worn pulley and will break eventually too
Apr 04, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My maytag electric dryer squeaks when it stars up and sometimes during operation.
most common causes of a noisy dryer are bad drum support rollers, a bad idler pulley or a bad blower wheel
May 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer squeaks during cycle
How do you replace the glides/slides? I have a Maytag dryer that's squeaking, took off front and it's clear it's the glides. Found where to buy them just need directions for replacing. Anyone know how?
To change the glides you have someone lift the drum--after taking off the front panel--and pull out the glides. We bought the glides locally and just ordered on line the felt pads that go under the glides, as one was missing. So I haven't actually completed the project but should easily be able to once the felt pads arrive.
Mar 23, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Dryer Repair
Easy fix.
Open the top cover by insrting a putty knife in the top right and left sides where the top meets the bottom cabinet.
Lay the top to the back.
Remove 2 screws on the right and left front inside corners of the cabinet.
Remove the door.
Replace the belt around the drum and motor pulley.
Re-assemble the dryer.
Mar 10, 2009 | Maytag PYE2300AY Electric Dryer
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
189 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
